Question about Hoover Refrigerators
I have a Hoover Contour HE430TF fridge leaking water to the bottom of the crisper. There is no internal drain hole. Hoover has no record of a 20 yr old model & is no help. How can I fix the problem?
    New Friend:
  • 28 Answers
It's not leaking water.. it's condensation running down the back of the fridge.. normally this is channelled into a hole that has a tube on it, that allows the water to go to a drip tray on top of the (warm) compressor, which then evaporates it.. Please re-check for a "V" shape moulding on the back if the fridge.. there SHOULD be a hole smack bang in the middle, which may have clogged up in the pipe with gunk, causing water to refreeze and block the hole completely.. best to do a full empty and clean, and use a chopstick, or better still a cheap pipe-brush from the £ shop, to clear that tube (about 1/2 inch diameter, or maybe less.)
Posted on Apr 24, 2017
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
On my kenmore fridge 970-671020 there is a continuous water pooling on the bottom where the crispers are do we fix it
not a good model number,if the freezer is on top and water is under the crispers you have a blocked drain in the freezer,when the machine goes into defrost a heater comes on and melts all frost off of the evaporator coil,the water goes down a drain hose down to where the compressor and condenser coil is and evaporates,you drain is blocked and the water is leaking into fridge section.remove everything from freezer,shut it down first or unplug it,remove the back inside wall of freezer,look under the coil and you'll see ice,melt it out with hair dryer and remove any ice on freezer floor,then heat up the drain hole,you can stick a screw driver into the hole,it will help melt the ice out,i use a steemer to do this job,if you don't have one use anything that will push air into the hole like a turkey baster,when you think it's clear pour hot water into hole,if it drains down you're done,if not keep hitting it,you can open the fridge door and heat up the center part of ceiling and back wall,this is also where drain is,if it happens again you can buy a heater probe or make one out of a piece of copper wire like the ground wire in house electrical wire,cut like a six inch piece,stick it into the drain hole and rap the other end around the heater,when the heater comes on the copper will heat up to keep the drain open,if the heater is glass there will be a metal cover,connect the copper to the metal and it will be fine.good luck,if you need more helplet me know.salde
Jul 12, 2012 | Kenmore Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Fridge is leaking water from top of fridge and water in bottom of fridge
The defrost drain hole is plugged. you must open that and then the water from defrosting will not pool up below the crispers in the bottom of the frig. Generic ice box Manual and more Here
Jan 27, 2011 | Whirlpool Refrigerators
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
Our Maytag MTB1976HRW leaks water under the crisper drawer. The drain has stopped up before but if this is the problem how do we solve this without having to call a repair person?
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Hope this helpout......
Jul 28, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 30, 2009 | Refrigerators
I need a HE430TF door shelf.
Try screwing some long self-tapping screws in to hold the shelf on.
Mar 24, 2009 | Delfield Series 6000XL Remote Half Height...
Water is leaking out of the bottom of the interior of our Contour Refrigerator.(HE430TF) It does not appear to be flowing into the defrost overflow tray. I have poked a piece of fexible plastic up the pipe...
Hi Richard,
I don't have any knowledge of your particular model but on mine the water condenses on the cold plate in the fridge compartment and then drips down into a little channel. From there it goes down through a fairly small tube which opens onto a little dish formed on the top of the compressor unit. This unit is warm when running, and the water is supposed to evaporate away into the room.
If water is collecting on the floor of the fridge compartment it is almost certainly due to a blocked drain pipe. If the drainage channel has become cracked this might be another cause of your problem.
One way to check that the drainage pipe is clear is to blow up it (not blow it up !) but that is a pretty yucky job. Alternatively you could pour a little hot water with dishwashing detergent dissolved in it into the drainage channel and check that it comes out onto the compressor top.
I hope this helps, but if not please defer a rating until we have had another think about it. Cheers, D.
Jul 09, 2008 | Hoover Refrigerators
Refrigerators Logo
63 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
