Question about Garden
My 18.5 hp briggs was not turning over, acted like it was fighting compresion. Valves were lose set valves at .004. started right up but blew alot of gas out. Ran good for about 5mins then it stalled and stated to blow blue smoke. It will stop can restart but it will start the same thing. It also blows oil out the fill tube if you take the cap off. Terry
    President:
  • 1,564 Answers
The oil out the fill tube is normal with the cap off, believe me I know about those un expected showers. Your problem sounds like fouled plugs because of the gas bath. Put in a new plug/plugs and I'm sure you'll be all set.
Posted on Jul 24, 2009
What are the valve clearence settings for intake and exhaust on 20hp b/s #461707
.004"-.006" on intake and exhaust valves cold engine. I would set them at .005" .
Feb 16, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Runs good-but has no power under load
reset the valve clearance to .010 and .012 as they will holding open when hot and upsetting the carby flow
May 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
24 hp briggs motor Hard to start. It acts just like starter is dragging. turning the key sometimes results in a click. turn off and back on maybe another click or starts turning slow at first then speeds...
the starter is probably fine. the valves are out of spec. from what you described. if the valves are not set correctly they will not open and close right. take the valve covers of and check to see what they are. ill bet they are way off the should be at .004 and .006. just set them both at .005 and it will start as good as it did when it was new. its a good idea to check all of the electrical connections to be sure they are are all clean and tight.
Jun 18, 2017 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a 24 hp briggs, model 445777, type
I believe this does have comression release. Make sure you're rotating the motor in the correct direction, as I think the compression release only works in one direction. Adjust the valve to .004 with the piston at TDC make sure it's on the power stroke. Turn the motor till intake opens, then when you continue to rotate crank, unitl valve closes and piston gets back to TDC. Adjust both valves to .004. Then do the other cylinder the same way.
Jul 21, 2010 | Briggs & Stratton Garden
Cant set valves clearance
Set both intake/exhaust valves at .004 with piston 1/4 inch past top-dead-center on compression stroke if this machine has a Briggs in it
May 19, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Jun 21, 2009 | Briggs & Stratton Garden
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
75 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
