Question about The Health & Beauty
Hoveround MPV5 serial #5833255 -I need to find out the year of manufacture
SOURCE: How do I lock up my Hoveround MPV5?
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
Posted on Jun 28, 2009
  • 103 Answers
SOURCE: Where might I buy a new joystick controller for my
You need to contact hoveround. Only Hoveround dealers can work on hoverounds and get their parts.
Posted on Dec 16, 2009
SOURCE: my mpv5 hoveround has lights that go on, but
My father in law has a hoveround and it is in the lock position but we can't remember how to unlock it.
Posted on Jun 08, 2010
HoverTech
  • 232 Answers
SOURCE: Online owners manual for Hoveround MPV5
The full manual is not available online. It must be purchased directly from Hoveround for $20 plus shipping. Please call 800-964-6837, you will need the serial number from your power chair, located inside the manual brake release above the footrest.
Posted on Oct 29, 2010
HoverTech
  • 232 Answers
SOURCE: My Hoveround mpv5 will not turn on charger states
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, type U1, 24v 33 amp, found at Batteries Plus, Insterstate Battery or any other battery warehouse for $75-120 each.
To replace the batteries:
Remove the black power cords behind the battery covers by squeezing the plastic pinch clip. Remove the cover carefully by unhooking the black webbing strap so that you do not yank any of the leads. Using a 7/16" wrench loosen the bolts that attach the leads to the posts, be careful if there is any corrosion that may irritate your skin. Check the fuses to make sure they are still good; if not they are regular automotive fuses that are inexpensive and can be found at any auto parts store. Remove the plastic caps or any packaging from the new battery posts and seat the batteries on the tray, connect the leads to the posts as indicated and tighten with the wrench. Place the batteries back ont he tray, reconnect the power cord, Replace the covers, and tighten the straps.
You may want to use the power chair until the battery is used up before you charge it fully for 8-12 hours; this will ensure that the battery gets FULLY cycled and any buildup inside the battery from it sitting on the shelf in the store is burned out. Make sure that you charge the power chair after a full day's use for 8-12 hours (overnight), not after every trip as overcharging can cause damage. If the power chair in not going to be used for a while, continue to charge the batteries at least one day a week to keep the batteries fluid.
Return your used batteries to the battery store or auto parts store for proper disposal. Good luck!
Posted on Nov 02, 2010
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Sep 30, 2014 | NRS Hoveround MPV 5 - Used Power...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
Serial 351985 number hoveround
The serial number typically does not have any involvement with Medicare but is used by manufacturers and DME providers to track the chairs. The true definition of what is a group 2 power chair would take a long time to explain but single option Group 2 chairs are coded: K0835-K0840 for single power option and K0841-K0843 for multiple power option.
The specific code depends on the specific chair the person meets medical coverage criteria for. The Hoveround MPV5 you have pictured would typically be K0836 - Power wheelchair, group 2 standard, single power option, captains chair, patient weight capacity up to and including 300 pounds
Jul 24, 2014 | NRS Hoveround MPV 5 - Used Power...
Oct 28, 2010 | NRS Hoveround MPV 5 - Used Power...
Need a owners manuer for hoveround mpv5
Contact Hoveround at 800-964-6837. If you are not the first owner of the power chair, you will need to register your chair into your name so that a part order can be created. Manuals are $20 plus shipping. To register your power chair, give them the previous owner's name or the serial number, which is located in the opening for the manual brake release just above the footrest.
Oct 24, 2010 | NRS Hoveround MPV 5 - Used Power...
LOOKING FOR CONTROLLER FOR HOVEROUND MPV5
Those are only available through Hoveround and retail for around $1159.00. You may want to have a Hoveround Tech come out to diagnose the power chair for $50 to make sure that is what you need before spending that kid of money.
Aug 27, 2010 | NRS Hoveround MPV 5 - Used Power...
I lost the Hoveround MPV5 manuals
Hello. Call the company directly to get what you need
1-800-542-7236
Mar 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Where might I buy a new joystick controller for my mpv5 hoveround scooter.
Nov 22, 2009 | NRS Hoveround MPV 5 - Used Power...
My hoveround MPV5 will not operate. fully charged battery charger light turns green. the brakes are in run position and when the unit is turned on the charge bar just flashes and the chair will not...
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 14, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
Top The Health & Beauty Experts
Donald Pera Deane
Donald Pera Deane
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
