Question about Pro-Fit Pro.Fit Cv 76 98 Chevrolet/Gmc Suv'S 98 Up
1996 gmc fuel pump.
Wife was going up driveway car started to spit like it was running out of gas then it died.i checked and fuelpump was not running. i put new pump,straner,new pump relay still nothing pump still will not run. i neeed help bad,fast
  • wirehanger May 11, 2010
    brand new filter to. the pump will not even come on. . when you trun key on you should hear pump for couple sec. but i hear nothing.
  • 103 Answers
Try changing the fuel filter, should be near under the drivers door. Also, run some Seafoam through the gas, put a can of it in your gas tank.
Posted on Jul 24, 2009
91 Gmc 5.7 spitting and sputering
Check your fuel filter again. Dirt from the tank could have clogged it again.
Oct 24, 2012 | 1997 GMC Sierra
I got a 1998 jimmy with the 4.3 vortec. Engine my wife was driving it when all of a sudden it started to spit and sputter and die out it would start up fine and idle great but as soon as you go to push the...
This could be a blockage in the carburator,try to clean it, especially the valves. There is a specific spray for the job on the market. You might need to dismantle it.
Jul 20, 2017 | 1998 GMC Jimmy
I have a 1995 gmc jimmy. When I purchased it (used) the check ingine light was on. I was told that it was checked out but there was no problem with the vehicle light was just on (bull). The vehicle ran bad...
Try replacing oil pressure switch. Your oil pressure switch controls fuel pump. (safety issue) in case of roll over or accident so fuel pump doesn't run while engine stalled or of.
Feb 24, 2011 | 1995 GMC Jimmy
Gmc yukon turns but will not start dont hear the fuel pump on in the fuel tank
With ignition key on run, use test light to verify you have positive & ground to fuelpump. No power (positive) check fuelpump fuse. No ground check fuelpump relay. If both positive & ground fuelpump needs to be replaced.
Jan 17, 2011 | 1993 GMC Yukon
My Saturn has been sitting in my driveway for about a year and a half. We just replaced the battery and the fuel filter and when I try to start the car, the engine turns over, starts for a minute, and then...
If the gas in tank is that old you need to drain it. Once you have good new,clean fuel in tank. Turn key to run position,(do not energize starter just want red lights on dash to come on) listen for fuelpump whine. It will shut off. Turn key off.Turn key to run again, listen for fuelpump again. Turn off key again. Repeat this procedure total 5 times. On last time turn key to engage starter. It should build up enough pressure & fuel & start right up.
Jul 01, 2010 | 1999 Saturn SL
Gmc sub wont start 1996
It sounds like the fuel pump. You may still be able to hear the pump, but it needs to produce a lot of pressure. If it is weak it won't do the job.
Jul 01, 2009 | 1996 GMC Suburban
2002 gmc siera turns over and starts but dies immediatly
U NEED TO CK THE FUEL PRESSURE 55 TO 62 PSI.IT CAN LOOK LIKE U HAVE FUEL.IT MAY NOT BE ENOUGH.IF U HAVE LOW PRESSURE CK THE FUEL FILTER BEFORE U CHANGE THE PUMP
May 05, 2009 | 2002 GMC Sierra
2001 GMC safari stalled
I have had a distributor cap and rotor corrosion problem that caused my vehicle to not start. It also chugged before dying. Today I once again replaced the cap and rotor. There is a bulletin addressing this problem.
Apr 05, 2009 | 2000 GMC Safari
Gmc truckturns over but won't start,fuelpump.
Hit the bottom of the fuel tank. This jars the fuel pump. If the truck starts You need a pump. Common problems to GM is the pump.
Mar 01, 2009 | 1998 GMC Sierra
1996 GMC Sierra 1500 truck fuel problem
Have you check the injector relay or maybe a fuse for injectors.
Aug 26, 2008 | 1996 GMC Sierra
Pro-Fit Pro.Fit Cv 76 98 Chevrolet/Gmc Suv'S 98 Up Logo
96 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
