Question about Freezers
Why wouldn't an upright freezer work if turned off for a long time
  • 923 Answers
If the refrigerant (freon?) leaked out, the low pressure switch would not let the compressor start. Do you have any way to read the static pressure (without the unit running)? It probably had R22 freon in it originally.
Posted on Apr 24, 2017
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ... > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Frigidaire GLFH17F8HW upright freezer has stopped working. electronic screen is messed up with power loss lights on.
This is the part that is most likely bad:
Aug 24, 2015 | Frigidaire GLFH17F8HW Gallery 16.6 Cu. Ft....
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Upright freezer got wet @ bottom when basement flooded, is it worth fixing?
If you replace the starter on the compressor unit and start capacitor and timing unit, will work as new. good luck, take ur unit upstairs next time. Russ
Sep 02, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
For the second time in the 4 or 5 years that I have owned my Kenmore 16.7 upright it quit cooling altogether again -- the first time I cooled the compressor with a damp (to wet) towel and a fan, being...
If the compressor is overheating I would check the condensor fan and make sure it's turning. Sounds like you wouldn't have noticed this already though. Also, if the compressor is turning on for 5 or 10 seconds and then clicking off then your start relay is probably bad. Pull the relay off the compressor and shake it. If something is loose inside then it's bad. That is, if it's a whirlpool made kenmore. Kenmore doesn't make appliances they only brand them. The refrigerator could have been made by Whirlpool, Frigidaire, GE, LG, Maytag, Amana, or other. So, it's depenant on who made it.
Nov 24, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
model EV150N A O
14.6 c.f
Dec 19, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezers Logo
93 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
