Question about Kitchen Appliances - Others
I have a recipe that has 1/4 inch of water. Can you convert that to something I can understand.
  • Brett Duxbury
    Brett Duxbury Apr 24, 2017
    Hi Michele Block, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    What are you making ?
    quarter of an inch ?
    Probably an american Cubic inch which converts to 4.1 ml of water .
How convert 10 Cubic's to kgs
For cubic inches to kgs conversion use the link below.
For cubic meters to kgs (liquids) conversion use the link below:
For solids like concrete:
Amount: 1 cubic foot (cu ft - ft3) of volume
Equals: 68.15 kilograms (kg - kilo) in mass
Apr 20, 2017 | Office Equipment & Supplies
I need to convert 300 grams of mascarpone italian cheese into something i can understand
Don't forget cups are measurements of volume not weight. It was so the old west cowboys could cook using their tin mug as a measure. The problem with converting weight to volume is as follows, a cup of sugar is heavier than a cup of flour. Whole almonds have air spaces between them. This site is a flour site, but lower down, cups of various ingredients by weight. With the two sites listed, you can convert everything. Good luck, I am a trade chef.
300 grams is 10 1/2 ounces
200 grams is 7 ounces
This calculator site will convert everything including grams to ounces and using the 'VOLUME' tab, grams to cups.
Kitchen Calculator MyKitchenCalculator com
Dec 10, 2016 | Kitchen Appliances - Others
I need to know how to get 100 grams converted to cups and 125 grams into tablespoons for a recipe please
I believe it would be much easier for you to use a kitchen scale.
1 cup is a measure of capacity (volume). The same volume of two different substances will correspond to different weights. Some substance are light, other are dense.
1 cup is about 236 mL. For cold water 1mL corresponds to 1 g
A table spoon is about 15 mL. With water that corresponds to 15 g. Recipes are not laboratory protocols that must be followed exactly.
Oct 29, 2013 | Office Equipment & Supplies
How can I make a recipe fit in my novelty rose cake pan?
There are two ways to do this. You can go by the volume of the pan and convert the recipe to fit it. For example an 8 by 8 inch pan makes 6 cups while a 10 inch bundt has 12. The easier method id to make the full recipe and then use as much batter as you need for the special pan and just use the rest to make another cake or a couple cupcakes.
Jan 14, 2013 | Home
I've lost my recipe book which had the best corned beef and cabbage soup recipe. Does anyone have this recipe?
is this the one?
Tangy Corned Beef and Cabbage Stew
You don't have to be Irish to enjoy this lovely dinner.
  • 3 pounds corned beef, rinsed and cut into 1-inch cubes
  • 3 tablespoon quick cooking tapioca
  • 3 medium carrots, cut into 1-inch pieces
  • 2 medium onions, quartered
  • 1 small head cabbage, cut into 8 wedges (do not remove the heart)
  • 1- 10 1/2 ounce can beef broth
  • 1 soup can water
  • 2 tablespoons wine vinegar
  • 1/2 teaspoon dry mustard
  • 1/2 teaspoon horseradish (optional)
  • 1/4 cup molasses
  • 3 whole cloves
  • 1 bay leaf
  1. Place corned beef in pot. Sprinkle tapioca evenly over meat.
  2. Spread carrots, onions, and cabbage evenly around and over meat. In a mixing bowl, combine beef broth, water vinegar, dry mustard, horseradish, molasses, cloves and bay leaf. Add to pot.
  3. Cover and simmer at Setting #4 for 6 to 8 hours or until vegetables are fork tender. Remove cloves and bay leaf. Keep warm for serving at Setting #2.
    Makes 6 to 8 servings.
    Here is the link to recipes:
    Please rate FIXYA
Apr 09, 2011 | West Bend Crock Pots & Slow Cookers
Cooking corn on cob, heating up brisket, cooking beans
1. How long does it take to cook small corn on the cob and do you add water?
20 minutes once the water starts to simmer. you only need to half cover the corn.
2. What temp do I heat up already cooked briskets, how do I keep it moist, and how long?
Add a half inch of water, 300'F for 30 minutes
3. How long do I need to cook pinto beans and at what temp?
1 hour at 275'F
here is your manual with recipes
Recipe ideas for you
rival 22 qt roaster oven recipes Google Search
Jan 03, 2018 | Rival 18 Qt Roaster Oven with Buffet...
Searching for pasta sauce recipe
Barbara....I understand -- I panicked to day when I couldn't find my CROCK-POT recipe book for my Chicken Cacciatore recipe. I think I have that same recipe book -- my CROCK-POT is avocado green. Tthere are two recipes for spaghetti, but I'm assuming that you want the "Italian Meat Sauce" recipe. If not, let me know and I'll send the other one.
Crock Pot Italian Meat Sauce
1 cup chopped onions
1 – 1 ½ pounds ground chuck, browned
2 cloves garlic
1 large can tomatoes (28 oz)
1 6-oz can tomato paste
2 stalks celery with tops, chopped
2 teaspoons salt
3 teaspoons dried oregano
¼ teaspoon dried thyme
1 bay leaf
Put all ingredients in CROCK-POT. Stir thoroughly. Cover and cook on Low for 10 to 12 hours. (High: 3 to 5 hours).
Feb 21, 2009 | Rival 3100 3.5-Quart
Bread is falling during baking
I had this same problem. It has to do with the amount of water and the amount of yeast you are using. I decreased my amount of water to 1 cup ( of course it depends on your recipe) and I also was using rapid rise yeast which calls for a less amount (usually 1/2 tsp less than what the recipe calls for). I did experiment with the recipe until I got it just right. Good luck. Carrie
Jan 16, 2009 | Welbilt ABM3500 Bread Maker
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
