Question about Blomberg Washing Machines
Blomberg washing machine won't start. It appears C on on the display. What should I do to make it work?
4 Suggested Answers
SOURCE: blomberg washing machine
I have a blomberg washing machine AAA rating with "fuzzy logic". Now it is not working, will not fill with water or spin, but you can see the dial turning and going through the dial settings. Whats wrong. Can anyone help and I have lost the manual.
Carla
Posted on Aug 29, 2009
caroldon
  • 17130 Answers
SOURCE: Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Posted on Nov 11, 2011
How i can to reset Blomberg dishwasher
first thing to do is unplug for 3 minutes plug back in. Reset?
restore the factor settings:
1.
Enter into the "Settings Menu"
(Press Function and Time Delay
Buttons together for 3 seconds)
2.
When the Main Menu is displayed,
keep the Function Button pressed
until "Restore Factory Settings? is
displayed.
3.
Factory Settings menu do not
have any submenus and it is
enough to press "Confirmation
Button" to reset the settings.
4.
Exit the menu after "** Stored! **"
is displayed
hope this helps.
Jan 07, 2018 | Blomberg Washing Machines
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Washing Machines Logo
216 people viewed this question
Top Blomberg Washing Machines Experts
vince
debbie
Level 1 Expert
Eric Taylor
Are you a Blomberg Washing Machine Expert? Answer questions, earn points and help others
