Transmission when reset work 4 minutes and them put in blank
  • Computers & ... Master
  • 923 Answers
Your wording is very confusing and makes no sense! "Them put in blank?" What does that mean, exactly?
Posted on Apr 24, 2017
A Lidl supplied digi-tech 4-LD1798-6 radio controlled alarm clock with built-in indoor thermometer and separately powered outdoor temperature sensor each needed 2 fresh alkaline batteries. However after...
To solve LIDL 4-LD1798 weather station blank display issue, take the batteries out of the base unit for at least 30 minutes. After 30 minutes, push each of the buttons on the front panel 20 or more times. Then put the batteries back in, and voila. My unit had the same problem, and these steps restored the display.
Aug 30, 2013 | Audio Players & Recorders
Computer fires up but screen blank
Try resetting your BIOS.
This can be done, by removing the battery. Then after about 1 minute put it back in.
I've you still have a blank screen, contact the manufacturer.
Jun 08, 2011 | Acer Aspire 6930-6771 Laptop
1997 buick park ave ultra After I replace the battery, do I need to do anything to reset the electronics?
Usually when you replace the battery, you lose the memory settings on your radio, power seat memory and any other accessory memory settings. The engine might also have to go through an idle relearn process. The engine might run erratically until this process is completed. One way to avoid this problem is to install a memory saver, available at most parts stores and are relatively inexpensive. They come in two types. One uses an electrical outlet and the other one uses a square 9 volt battery. It plugs into the cigarette lighter or 12 volt adapter. Install the memory saver and leave it plugged in until you are done installing the battery. If you use one of these, then you do not need to reset anything. If you don't then you might need to reset your accessory memory functions and have unstable engine operation until the idle relearn is completed. Although the computer will correct the problem on its own by driving it, you can speed up this process by performing a manual idle relearn procedure.
1. Start the engine and allow it to run in park position with all the accessories off for one minute.
2. Put the transmission in drive with all accessories off and let it idle for one minute.
3. Put the transmission back into park and turn all of your accessories on for one minute.
4. Put transmission into drive with all accessories on for one minute.
I hope this information is helpful to you and thank you for using
Jun 05, 2011 | 1997 Buick Park Avenue
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Forgot password and hint for laptop cant get back into it ???
There are two tips for you to reset windows password .
1. Enter into safe mode, log in as default admin account, there is no password in it. If the default account password has been changed, see next
2. Find Windows Password Reset and download it from ( You can do in any computer not yours). Burn to a blank CD or USB, Insert it to your computer then use the disk to reset your password to blank without knowing the current password.
Jan 11, 2011 | Sony VAIO VGN-AR630E Notebook
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
Blank screen with new batteries! TI-84 Silver Plus
ON, 2nd, [up] arrow to change the contrast. Works 99% of the time....
Oct 19, 2008 | Texas Instruments TI-84 Plus Silver...
Buick shakes, guns then almost stops
this sounds very much like a torque converter/transmission issue. i will assume the transmission dial you're speaking of is the tachometer? which measures engine revolutions per minute. to confirm, one could possibly unplug 4-wire connector on transmission near radiator and test drive. this keeps the transmission from going into torque converter lock-up.
Oct 03, 2008 | 1993 Buick LeSabre
BIG problem. PLZ help!!! :(
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Apr 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Computers & Internet Logo
David Payne
David Payne
