Question about The Audio Players & Recorders
Just bought txnr757....connect the speakers and there's no sound at all. what is the problem
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
Bought new Infinity 8" speaker
hook them up and play something,, the speaker should bounce "out" on bass sounds, if it pulls "in" switch the wires
May 04, 2011 | Infinity BU-1 Speaker
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
When I plug the speakers in, No sound comes out of them.
Hi, have you tried any speakers on your computer before if yes and these speakers you bought are not working even you turned the volume up they may be faulty, else it may be a cable problem, jack has not been connected at the right place or the sound driver is not installed on your computer. try to check if all is OK or even check the speaker by connecting it to an mp3 or any device using this type of jack if it is playing the problem may be on your computer.
hope that this will help and don't hesitate to contact me and don't forget to rate.
Best regards
Damien C
May 23, 2010 | Logitech V20 Computer Speakers
Speakers crackling and making a 'clicking' sound when volume high
The cable you are using to connect to the speakers could be duff or the connectors could just be dirty.  clean the connectors and push it in and out of the socket repeadedly to ensure you have a good connection.  Or you could try a different cable.
Mar 01, 2009 | Logitech Z-5300 Computer Speakers
Less center speaker sound
i give two solutions
1. Buy Amplifier.
2. Buy stereo converter.
Jan 15, 2009 | Creative Labs Inspire T6100 Computer...
Side Speakers
have you checked the settings on the default windows settings to surround? just a thought!
Feb 19, 2008 | Creative Labs Inspire T7900 Computer...
NO SOUND
Check speaker terminal connections, then source input, then surround mode choice.
Dec 12, 2007 | Teac AG-D8900 Receiver
Sound issues
You need to check that all the speakers wires are connected! It might be due to improper connections! This cause an resistance! And hence due to this the sound may be less or distorted. Check all the connections!
Oct 24, 2007 | IBM 02K4241 Computer Speakers
24 people viewed this question
Top The Audio Players & Recorders Experts
isojim
Level 1 Expert
 Sam R
Sam R
Level 1 Expert
obsteiner
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
