Question about RCA Televison & Video
Rca DVD recorder shows hello on display, no functions with any buttons, unplugged & plugged back in, hello shows back up
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
GSAN
  • 106 Answers
SOURCE: dvd player/recorder
Like many RCA products that use a DVD Burner, these burners are not high end ones and go out without warning and the first indication is the dreaded HELLO issue. I have tried contacting RCA and the makers of the DVD-RW drives but still I am in the dark as to any possible firmware/software updates for these devices. No fix to this date, only replacing the DVD-RW will resolve this.
Posted on Sep 29, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
Mike Adams
  • 19 Answers
SOURCE: RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 27, 2008
Mike Adams
  • 19 Answers
SOURCE: hello?
Symptoms
The unit's remote control and front panel buttons act completely dead. The unit locks up after displaying "hello" on its front panel and refuses to do anything more. In other cases, the front panel display appears completely dead. In this instance, the unit will display "Interface error" or "Interface error! Turn off the power" on the television screen and do nothing more.
In all cases, if a DVD or VHS tape was inserted just prior to the failure, you won't be able to remove either from that point further. They'll remain stuck inside the unit until you've completed the repair contained in the guide below.
Critical information you need to know immediately
If you haven't done so already please unplug the unit's AC power cord and leave it that way until you're ready to begin the repair. Taking this action will guarantee no further extensive electronic or mechanical damage can occur.
Under no circumstances attempt to remove anything stuck inside the unit until the repair has been completed. Should you attempt to do so you'll almost certainly damage its ultra-delicate DVD and VCR mechanisms which are very expensive to replace!
Once the necessary electronic repair has been completed, you'll easily be able to remove them in the customary manner without any problem whatsoever, by simply pressing the EJECT or OPEN/CLOSE button.
Why your unit has recently failed
The cause of all the above symptoms are entirely due to an inherent manufacturing defect in the unit's internal power-supply board, all of which will ultimately fail due to one or more defective capacitors contained on it.
Known brands and models affected
Audiovox DVDVCP01
Durabrand DBDVR01
LG RC797T and RC897T
Memorex MVDR2100, MVDR2102, MVDR2102A, MVCD2102 and MVCD2102A
Panasonic DMR-ES15, DMR-ES30V, DMR-ES35V, DMR-EH55 and more
RCA DRC6200N, DRC6355N, DRC8030N, DRC8040, DRC8052N
RCA DRC8060N, DRC8295N, DRC8300, DRC8300N, DRC8310N
RCA DRC8312N, DRC8320N and DRC8335
...plus many others not yet identified - please contact me if your's isn't listed above
Completely restore the unit yourself in under 20 minutes for just a few dollars
This simple repair doesn't require any prior knowledge or experience with electronics, takes less than 20 minutes from start to finish and typically costs between $1.59 and $5.00 for the replacement parts obtained from your local Radio Shack. All that's involved is simply replacing one (or occasionally just a few more) defective capacitors on the unit's internal power-supply board which are most often running painfully hot to the touch.
The repair guide is provided to anyone who needs it simply upon request
Upon discovering the massive quantity of Chinese manufactured combo recorders having this inherent defect, in addition to the callous manner RCA Thomson and other manufacturers were leaving their loyal consumers out in the cold whose units had completely failed thru no fault of their own, it so enraged me I was compelled to fight back. That was just 3 short months ago and the day this Combo Recorder repair brief was born.
How do I obtain a copy?
Just send an email to my public address provided below. Please include your brand and model followed by "repair brief" in the SUBJECT line. For example, "RCA DRC8335 repair brief" and I'll send it using my private ISP address as soon as possible. Email your request to mikeadams110@yahoo.com
Why don't you just post the repair brief directly on Fixya?
Due to the dynamic nature of its content, the repair brief's constantly being updated on nearly a daily basis, as new information becomes known that wasn't previously. Unless the repair brief is kept at one centralized location, it becomes impractical to manage and keep up to date. Many of the DIY repair forums like Fixya don't even provide the author any way of updating their prior submissions.
Why are your posts often so long?
They're whatever length they appropriately need to be. Nobody likes having to read a long post until it happens to be the one supplying the ideal solution to their problem--in which case it's never long enough!
Can I really do this repair myself?
Over 1,000 combo owners just like you have successfully restored their units using this DIY repair guide during the past 90 days! Below is a tiny handful of the nearly 1,000 follow-up messages I've received to date. Ann's follow-up message is an excellent example demonstrating how new strategic information is provided by your direct feedback and why it's essential the repair brief's kept up to date.
December 27, 2008 received by email from Ann M.
Just like John H, my problem was also capacitor C226, but in my case overheating wasn't the give-away here. Instead, I noticed the bottom of the capacitor appeared melted a little and the top looked like it was slightly bulged. I removed the damaged capacitor and replaced it with a new one rated at 35 volts and now my DRC8335 is working perfectly again!
December 15, 2008 received by email from Mike J.
Mike. Just recently discovered the link to your repair brief posted on AnswerBag and wanted to let you know my previously dead DRC8320N combo recorder is now working perfectly again! Even though I'd never worked with electronics before, following your excellent instructions made the task easy. Bless you for having saved me a pile of money.
December 7, 2008 posted by TinyPeanut on AnswerBag
What Mike says works! My nephew went to Fry's Electronics store in California and got the part he suggested, in our case a 1,000µF 50 volt electrolytic capacitor as that's what they had on hand. He and my brother soldered it in and now my DRC8320N combo's working perfectly again! Thanks so much.
December 04, 2008 received by email from John H.
Mike. Thanks for providing this excellent DIY repair guide. My RCA DRC8335 is now performing perfectly again! In my case, the failure was caused entirely by capacitor C226 which I've just upgraded to 35 volts as advised, purchased from Radio Shack. Thanks again.
December 04, 2008 received by email from Glen
Dear Mike. Simply awesome, my DRC8320N combo's now fixed thanks to you! The only thing remaining I need to do is replace the VCR drive belt so its drawer will lock into place properly. Feel free to share my joy. Thanks again for all your help.
November 25, 2008 posted by Norstar448 on Fixya
I printed out Mike Adam's solution and phoned 2 electronic repair shops who refused to listen to how my machine could easily be repaired. The third said to bring in the info and my machine. He quickly located the part and replaced it and my machine is 100%. Thanks Mike!
November 14, 2008 received by email from Brandon
Mike. Since I last wrote, I've already taken my DRC8320N recorder apart, replaced capacitor #C232 and it's now working great! I repaired it myself without any electronics background or having done anything like this before. It really felt rewarding after putting things back together and plugging it in, to discover everything was working perfectly again.
Posted on Jan 10, 2009
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
With a rca drc8000 dvd recorder how to finalize recorded dvd without remote
You can stop the recorder by pressing power button to standby mode. Don't unplug the power from the electric source.
Dec 20, 2014 | RCA Televison & Video
When I use the timer to record a TV show with my DVD-R155, unit locks up.
If you can afford it purchase a TIVO. I had a a video and dvd player and it drove me mad. This unit records 2 programs at once with just the press of a button.
you can watch tv at the same time. Also you can rewind situations on live tv to watch it again. Top unit. I am 73 and I have no problem using it. Love it!
Dec 07, 2011 | Samsung DVD-R155
Dvd will not eject. tray will not open. pressing open causes "hello hello". is there a way to manually force the tray to open without damaging the dvd?
The DRC8052N / DRC8052NB / DRC8052NC DVD recorder (sorry cab209, not a PC) has had a LOT of problems. So many that RCA doesn't even list it on their site! There was a firmware upgrade that supposedly fixed this, but I'm having trouble finding it on the web.
As to how to remove DVD:
1) Try unplugging the machine and leaving it unplugged for 10 to 15 minutes. then (without plugging it back in) press the power button repeatedly. (I know it sounds goofy but it came from customer support. Theory: to drain all power) Plug it back in and try to eject.
2) Another owner suggested holding down the HDMI button on the remote. The "hello" mesage is an initialization/power-on routine, so my guess would be it was powered off with the disc in it?
3) Unplug it. Remove the cover (two silver screws on each side and three black screws on the back). Slide the cover off (to the rear). Take the four small screws out of the top of the drive (marked LOADER on mine. Lift out the DVD. Reassemble.
While you have it apart..... You might also look at the circuit board next to the drive in the center of the unit. It has a bunch of capacitors (black or blue, cylindrical, w/ X or Y stamped in the end). If any of these are no longer flat on the X or Y end or have yellow 'goo' on or around them, they have failed and are the source of your problem. They can be replaced, but it may be more cost effective to replace the entire unit.
Jim
Jan 02, 2010 | RCA DRC8052N DVD Recorder
My DVD Recorder & VCR (DRC8320N) has Hello on display
Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
Dvd player/recorder
May 13, 2008 | RCA DRC8052N DVD Recorder
Televison & Video Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
