Question about MaxOptic Maxoptix Star T5-2600 Internal Magneto-Optical Disk Drive
I need to know the pin assignment for maxoptix t5-2600 please
  • ivanmikeseoa Jul 25, 2009
    Please, I have a SCSI Magneto Optical Drive MAXOPTIX T5-2600 and I need the jumper configurations for SCSI directions. for example: I need to configure my T5-2600 for the address 1 of the bus SCSI.
    what can I make?
    Please, help me
    what can I make?
    Please, help me
  • 103 Answers
I need to know the pin assignment for maxoptix - moz-screenshot.jpg0bf7a8f.jpgHERES THE PIN ASSIGNMENT NEEDED
Posted on Jul 24, 2009
    Problem Solver:
  • 4 Answers
You can check more detail on this link : http://www.transtec.co.uk/doit/loadva/software/w3/TPM_PDC_BIN/treiber/maxoptix/t5-2600.html
But something you must need to know . T5-2600 & T5-2600* (T5-2600 star) were 100% not the same. Pin assignment were not identical.
I just using T5-2600 on SunOS 2.3 backup file system. Just place jumper on 19-20 & 21-22 ping. Your solaris read and write will quick & efficent.
Posted on Oct 24, 2009
  • ilupro Jan 02, 2010
    One More things to know SunOS 2.3 vold.conf no define MO disk as rmdisk as Solaris8 . So, if you want to using Maxoptix on Solaris8 or 9, 10 as HDD must comment out "use rmdisk ....." this line then reboot . Will done !! Nothing configure or patch . Nor using MO device driver as rmdisk .
  • uhrmacher201
    uhrmacher201 Jan 16, 2018
    Must edit vold.conf and add Maxoptix MO disk option. My Maxoptix MO disk configuration already forgot. After configuration then do command below. "drvcongif;disks" All done.
  • 130 Answers
Should be located by the power socket.
It may say "M, S, CS"
M = Master
S = Slave
CS = Cable Select
How to correct 'not assigned'
You need to assign an operator. It just means you haven't logged on to make sales. All sales are logged under an operator. You should have a sign on code given to you by the manager when the security side of the terminal was setup. If you don't know the secret PIN for sign on, you can program new ones. Most Sharp manuals are here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp1.php
Jan 07, 2016 | Retail Supplies
6 PIN DIN to RCA Converter Cable with power for security camera
WHOA we'll kinda hard when there are 50 different camera co out there need the camera co name and camera model
Jan 27, 2014 | Home Security
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
CORD OF MY MONITOR FROM CPU (15 PIN) TO MONITOR 2 PARTS HAS BEEN DAMAGE. I WOULD LIKE TO KNOW THE PIN TO PIN CONTACT
You can go to the following website:
http://pinouts.ru/Video/VGA15_pinout.shtml
The webpage describes in detail what each of the pins assignments are for the standard VGA 15 pin connector.
The above information should allow you to resolve your issue. However, if you need further assistance, please do not hesitate to post further questions. Thank you for allow us to assist you in resolving your issue.
Jun 27, 2011 | Computers & Internet
2008 road king classic(FLHRCI) has fob alarm problem. I have insert code 31313 and did not have able to reset or disarm. Charged battery full. please help
You may need to take the bike to a dealer and if they can get the alarm deactivated then re-program the fob and reset the PIN otherwise you need a new TSM/TSSM and have the fob assigned and a new PIN assigned.
Nov 25, 2010 | 2004 Harley Davidson FLHRCI Road King...
Just need the pin out assignments for J11 USB header on Compaq 431F9P01K7C motherboard. I am trying to use the front USB ports from an old Compaq case, case to, with new motherboard and need to know if...
Most motherboards (99.8%) use the same pin assignments, they just tend to place the connection in different location per board. With usb connections, you should be more than capiable of making the connection, possibly the only issue is do you have enough lenght to make the connection within the case. Good luck and I hope this helps you out.
C2Solutions
Aug 10, 2009 | Computers & Internet
DETAILED 34 PIN ASSIGNMENT FOR iNTEL se7520BD2
http://www.intel.com/support/motherboards/desktop/sb/CS-015851.htm
Jul 29, 2009 | Computers & Internet
Dell Demension XPS B866 N232 motherboard power pin assignments
dont take any risk with power supply. purchase a new compatible power supply to solve your prob...
good luck
shafyk
Jun 12, 2009 | Intel Motherboard
Maxoptix t5-2600 Will not eject MO Disk
As far as I know the green led means "write" & red led means "read". Don't increase time out on the SCSI card . If you press eject button wait 10 secs. If no response I think your MO drive having some problem . Or your jumper setting doesn't right.
I using t5-2600 on SunOS so I'm not exactly know what's problem on your drive. But Maxoptix MO drive very durable. I bought from ebay and manufacture date were 1999 . Oh my god . Just almost 10 years . And working good.
Apr 14, 2009 | MaxOptic Maxoptix Star T5-2600 Internal...
Pin assignment for 104S monitor cable
you will get right pin alignment& complete ckt from web site IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Feb 14, 2007 | Philips Standard 104S 14" cRT Monitor
MaxOptic Maxoptix Star T5-2600 Internal Magneto-Optical Disk Drive Logo
526 people viewed this question
Top MaxOptic Computers & Internet Experts
David Payne
David Payne
Are you a MaxOptic Computer and Internet Expert? Answer questions, earn points and help others
