My F&P model MW059AU top loader washer suddenly lost power and stopped half way through wash. Power point ok. Is this repairable?
    Top Expert:
  • Washing Mach... Master
  • 50,512 Answers
Possibly but you will not know until you get in a technician to do a proper diagnosis of the problem
Posted on Apr 24, 2017
I have Samsung front loader washing machine that stop working suddenly there is no power no nothing and I checked power supply and nothing wrong with power supply .
Your power supply normally connects to an EMI filter immediately upon coming into the washer. If you have a voltmeter and are comfortable with electricity, you should remove the top cover of the washer to access the connections. Unplug the washer and shut off the water while dismantling. Remove the 2 screws at the back of the top portion (lid) and push the lid towards the back to dislodge it.
At this point, you should be able to locate the incoming power cable and see where it connects to the EMI filter. Once you have identified the connections, plug it the washer and verify that there is voltage both before and after the EMI filter. If there is no voltage at the incoming side of the filter, then your cable is broken and should be replaced. If there is voltage on the incoming side of the filter and none on the outgoing side, your filter is open circuited and should be replaced. If there is voltage at all locations, look for wires that may have shaken off during operation. When poking around inside the washer, looking at wires, pull the plug first. If this does not help, take a picture of the schematic diagram that is affixed to the top of the soap dispenser/water inlet box and post it for our reference. I have attached a typical diagram from a older Samsung washer. section-yodzb2tavlblrpvbck4ieuwo-2-1.jpg
Jan 10, 2015 | Samsung WF337AA Front Load Washer
The power does not come on my fisher and paykall washing machine not sure what model but it is a 7.5kg top loader
if the display doesnt light up when u turn on power 2 unit it is one of 3 things, 1st/ no power at power point check with hair dryer or toaster, 2/ drain pump open circult. 3/ motor controller is faulty. hopefully it is the 1st option.please reply 4 more help
Apr 09, 2010 | Fisher and Paykel IWL12 Top Load Washer
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
Model 805 Simpson top loader. No Power, lights, nothing at all. Have checked power point with another appliance and is ok, is there an inbuilt fuse in the machine, or could the on off switch be...
If its the model i'm thinking of, there is a fuse located on electronic board. disconnect power. acess by removing 3 screws along top rear, top panel comes off. locate fuse-if faulty, fuse should be replaced with a 4amp slow blow fuse.
Aug 08, 2009 | Washing Machines
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Jun 22, 2009 | Washing Machines
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
Wont work at all
Need to know the model number and serial number before I can assist you
Jan 09, 2008 | Maytag Atlantis MAV8000
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
