Question about Sewing Machines
Husky 910 overlocker..left needle will not sew stitches...does not unthread just won't form stitches
  • Sewing Machines Master
  • 12,515 Answers
Be sure to install a brand new needle. Verify it is the correct needle for your machine and it is installed facing the correct direction.
Remove all the thread from your machine. (Clip the threads below the thread spools, RAISE the presser foot, and gently pull all the threads DOWN through the needle--NEVER up!)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify that you are threading each thread in the order specified in the manual--failure to do so will cause your machine to malfunction.
When threading, give each thread an extra little tug when going through the tension disk.
Set all the tensions to the midway point for a 3 or 4 thread overlock.
Test your machine.
If the left needle still fails to stitch, then your machine may need a timing adjustment.
Posted on Apr 26, 2017
I have a baby loc e605 serger I have checked to make sure I am threading correctly but when I start sewing the overlock needle comes untreated what am I doing wrong? I have already changed the needle.
Your tension is too tight perhaps, or you are using poor thread which has burrs that catch in the tension springs. Does the thread move easily when you pull it through by hand or does it catch somewhere? Is the needle in correctly?
Sep 09, 2015 | Sewing Machines
Fabric jam
NOT a home fix
Mar 30, 2014 | Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
I have a husky lock 234D serger and no manual. how do i use 3 thread overlock? which threads do i use?
To use a 3 thread overlock, thread the overlooper; the underlooper and then use ONE of the needles. Removing the RIGHT needle will produce a 5mm or 1/4" seam. Removing the LEFT needle will produce a 3mm or 3/16" seam.
Dec 17, 2009 | Husqvarna Sewing Machines
How do I change to straight stitching from overlock stitch please? I am using a friends Bernina1015 and she is in New Zealand!
Hi. Take out the looper threads and just leave the needles threaded. And if you want just one line of thread unthread one of the needles.
Of course then your going to have to rethread the loopers later to overlock in which case its important to do them in order.
Upper looper, lower looper, right needle, left. If yours is color coded as most are then the order would be blue, red, green, yellow.
Hope this helped.
Rick
Nov 05, 2009 | Bernina Sewing Machines
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Sep 12, 2009 | Husqvarna Sewing Machines
Sewing machine stopped making the stich
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
Jul 19, 2009 | Yamata FY14U4AD
Singer overlocker
Most likely is the left looper thread is trapping the needle threads.
Remove the threads and start over in this sequence....
Left looper - right looper - left needle - right needle.
If you thread the needles before the lower looper, the needle thread wrapped over the looper will be under the looper thread and will never be free to form a stitch, so the threading sequence is critical.
Jun 08, 2008 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
