Question about Sewing Machines
My bernetta is making a chirping sound sounds like from spool of thread area
  • 192 Answers
SOURCE: Designer 1
Please, take this machine to an authorized technician before you attempt to set the timing on your own. An authorized technician will have a device to quickly tell you whether or not the timing is incorrect. If you change the timing yourself and that isn't your problem, you will spend far more money getting 2 problems fixed than the one original problem.
If the machine is making what I describe as a chattering sound, you may be able to clean the bobbin case and the ledge that it sets on and the problem will go away. This bobbin case should be operated with no lubrication. Some repairmen recommend " a drop of oil to make it run quieter". This generally makes it chatter louder. If there is any lube on the bottom of the black bobbin case, wipe it off and wipe the ledge that it rests on.
By the way, if the needle is hitting the raceway, you will be able to see the marks where it is hitting. In a Viking machine, this is normally caused by the "needle to hook clearance", not timing.
Posted on Feb 19, 2008
Australian S
  • 46 Answers
SOURCE: BOBBIN PROBLEM
Firstly check that you have the correct bobbin for your machine, there are many bobbins that will fit in the bobbin case and sew ok, but the hole in the centre is what matters. If you do not have an original try putting the bobbin on the winder spindle with a small piece of paper inside the centre of the bobbin so it is tight on the shaft.
If that does not work it usually means the winder rubber on the bottom of the cover is worn or stuck, this part often looks like a large O Ring.
Posted on Jul 02, 2009
  • 54 Answers
SOURCE: When I try to sew
need to get it to a service center.....before u really get some bad problems
Posted on Aug 18, 2010
  • 109 Answers
SOURCE: Thread bunches up in the bobbin area and needle
Check to see if the thread coming off the spool is tangling on the spool pin or getting caught in the crack on the spool top where the thread originally comes off spool. Make sure the spool pin is pushed all the way to the right to secure your thread and then back it off slightly so the thread pulls evenly off the spool. Whenever your bobbin thread gets bunched it is usually something is wrong with the threading of the UPPER thread and vice versa. Let me know if this solves your problem.
Posted on Aug 23, 2010
bargainbox
  • 1388 Answers
SOURCE: thread keeps breaking at foot
Have a look HERE for basic Troubleshooting.
Bargain Box
Posted on Feb 13, 2011
When trying to load the bobbin with thread, only top half threads and is tangled. Has worked great till now.
Difficult to assess without a make & model.
The machine has a tensioner for the bobbin winder. Make sure that you are threading that tensioner before taking it to the bobbin winder. Also, sometimes the thread should make a complete loop around that tensioner (consult your owner's manual). Check that the thread spool is spinning the correct direction--most often the thread spool turns counter-clockwise on the spool pin. Running the thread the wrong direction could cause thread kinks or the thread plies to separate. Slow down the speed that you wind the bobbin. Fast speeds will cause the thread to stretch. Plus, if something goes haywire, you won't have a bobbin bouncing or thread flying all over the sewing room before you can stop the machine. Frequently, the bobbin will fill more in one area of the bobbin. You can gently guide the thread by pushing it up or down lightly with a pencil tip or other object to even the thread distribution on the bobbin.
Mar 31, 2016 | Sewing Machines
My top thread frays and then breaks while I am quilting with my 1600p dbx.
change to a new needle
check to make sure thread has no knots or even change the thread spool
check the top thread tension it sound like it's to tight
check the needle plate for burrs
check around the tension knob for loose pieces of thread or lint
use a can of air that you'd use on a computer keyboard on the tension knob & if you don't have the can of air use unwaxed dental floss but make sure to write down the setting it was on before cleaning.
& also under the needle plate area in case there is loose threads or lint & also the bobbin area
Aug 11, 2011 | Janome 1600P-DB Mechanical Sewing Machine
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
I havea 6000 emb machine. it breaks thread bad.just knots the end of the thread
check to see if the thread is catching on anything like
spool pin
notch on spool itself
sometimes thread comes off the thread take up lever-on some machine
check thread tension
check neelde to see if it's bent-roll on flat surface to see if it rolls correctly
if when sewing the is a popping sound when the needle goes thru the fabric the needle is blunt
check for lint & thread in bobbin case area
Sep 23, 2010 | Brother Sewing Machines
Thread bunches up in the bobbin area and needle appears to be stuck and won't move. Almost like the thread wont come off the spool.
Aug 23, 2010 | Brother XL-5500 Mechanical Sewing Machine
Hi why does the machine skip stitch ,or Cather at the bottom ,the problem occur while am sewing.
check to see if your needle is bent-roll on flat surface to see if it roll good
if the needle make a popping sound when going thru fabric it is blunt
the needle is incorrectly inserted in needle clamp holder
needle & thread not compatable with project
check for warped bobbin
rethread machine
check bobbin area for lint or loose threads
check to make sure thread is not caught on any thing-such as spool pin-notch in spool of thread
Aug 22, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
My top thread gets in tangle mess & does not pick up bottom thread
check to see if the thread is getting caught on the notch that on the spool of thread
check to see if the thread is coming off the thread take-up lever
check your needle to see if it's bent-roll on flat surface & see if it rolls good
blunt-if it makes a popping sound when the needle penetrtes fabric
clean bobbin case area for lint & loose threads
Aug 10, 2010 | Singer Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
