My tv turns on then turns back off - Televison & Video
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv...
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Dec 12, 2014 | Mitsubishi Televison & Video
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
While setting up the Crest Universal remote control RCP1F for my sharp TV, I've managed to turn the TV off, but now I can't turn it back on. The TV remains on Standby and turning off the power doesn't do...
OKAY TRY THIS..
DO STEPS 1-3 AGAIN AND ONCE IT TURNS OFF KEEP CLICKING THE CURSOR UP A COUPLE TIMES.
THEN START CLICKING THE CURSOR DOWN SLOWLY TELL THE TV TURNS BACK ON AND ONCE IT CLICKS BACK ON HIT THE TV BUTTON ON THE TOP OF THE REMOTE ..
IF THE LIGHT BLINKS TWO OR THREE TIMES MORE THEN LIKELY YOU'VE PROGRAMED IT =)
AND NOW KICK BACK RELAX AND ENJOY A COLD BEER FOR THE BOTH OF US =)
Nov 18, 2010 | Televison & Video
My T.V. will not turn off. The last repairman bypassed the swith on the back door of the T.V. Should I just repklace the little blue switch on the back of the T.V.?
That blue switch is in place to make sure that the back of the TV is closed properly. It prevents the TV from being turned on when the back is removed. It would not be keeping the TV from turning off. Replacing that switch would not solve your problem.
Oct 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I have 42 inch lcd philips tv. Sound does not work when I turn tv off and then back on. I have to turn tv off, unplug hdmi cable from back of my tv, plug back in and then sound will work when I turn tv...
something problem with your connection from cable to tuner, if in good contact. you need to remove back cover and re solder tuner ckt board side. specially in 32 pin ic.
Mar 07, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Sep 12, 2007 | Philips 25PS40S 25" TV
The picture on my tv is fuzzy
Check your connections Inm the Back of your Tv and Also see If your VCR got turned on By Mistake....
Jul 18, 2007 | Insignia IS 20" TV040919 TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
