RECODER WILL NOT OPEN UP seem to stay in standby jim
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Jensen Jims-225 wake to Ipod trouble
In standby mode Press the >>I to select iPod/Radio/Aux/buzzer as a "wake to" alarm
Dec 26, 2008 | GPX MW3837 MP3 Player
Comuter will not stay in standby mode.
So why do you need the computer in stand-by mode anyway? My computers are either on or off. Off saves power and hardware.
Dec 25, 2008 | Computers & Internet
How do i rechager battery
its to the right of the buttons when you open up the screen. pull open the plastic cover
Jun 06, 2008 | Samsung VP-DC161 DVD Camcorder
Won't stay on even in standby
The voltages are wrong. You should see (0.0, +/-0.6, and B+/B-) on the 3 pins. The driver section has a problem. Check the driver stage for shorted transistors or open resistors.
Mar 19, 2008 | NAD C320 2-Channel Amplifier
Hi, This is a common problem with some VHS units. The problem is that the tape does not fully extend over the video head and the slack sensor shuts the unit off. This involves the motor and driving mechanism that actuates the spreader arms that moves the tape. Usually this is caused by slippage of a small rubber belt. Though the repair work involve is relatively easy, removing the mechanism and replacing the belt would require that you be familiar with component placement and certain timing sequence of tape loading. Your best bet probably would be to seek the services of a qualified professional. Hope this be of some help/idea. post back how things are or should you need additional information. good luck and kind regards.
Sep 30, 2007 | JVC HR-S9500 S-VHS VCR
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
