Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Water on the floor from the defroster.
I have a Sears Kenmore # 363.9530780 Refrigerator and recently found the Refrigerator Door Gasket was broken which was causing condensation in the bottom of the refrigerator which dripped onto the floor. I replaced the gasket which seemed to take care of the problem but 24 fours later I had water again. It did not come from the door and the Ice Maker is not hooked up. I suspect the Defrost Pan but when I removed the cover at the back of the refrigerator the pan appeared to be empty and the fan was running. Any suggestions?
  • 36 Answers
Either the freezer drain is cloged or frozen or ther is condensation still inside the door witch will go away.asuming you got that new gasket to seal right.(the frezer drain is located behind the back wall of the freezer)
Posted on Jul 24, 2009
2 Suggested Answers
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
My freezer defrosted and the refrigerator is not as cold as it was
That sounds like the compressor start capacitor,relay or overload. It could even be the defrost timer or part of the defrost Adaptive Defrost Control. I will need the Sear Kenmore model number. I will need you to communicate with me and look around the door of the fresh food section for a model number. Sears uses a different model number when they sell a Maytag, Whirlpool or any Brand nam. Their number after changing would look like this 231.65489 near floor behind door seal and near kick plate.I will help you if you let me know, Thanks Sea Breeze
Nov 13, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
The refrigerator will not stay cold. The freezer gets as cold as 44 degrees.
I believe you most likely have a defrost problem. Look inside rear of freezer and see if there is a lay of frost building up on rear wall or floor, depending on what model you have it could most likely be the defrost timer or adaptive defrost. I need your Sears number that looks like this foe example 231.56489 on the bottom of fresh food door frame behind door seal and near floor kick plate. Your next most likely reasons will be defrost heater or defrost thermostat. If you find frost I want you to unplug and begin manual defrost. Remove rear panel of freezer after unplugging and use a hair dryer. That will give you a little time to see the problem and get answers to repair them, Sea Breeze
Sep 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Kenmore 106.53342300-side by side-icemaker not working..at all
IT COULD BE 2 PROBLEMS
1 .YOUR DEFROST TIMER IS BAD.
2. YOUR WATER INLET VALVE IN THE BACK COULD BE BAD.
BOTH PARTS ARE VERY INEXSPENSIVE(USUALLY UNDER 20 BUCKS AND YOU CAN GET FROM YOUR LOCAL SEARS OR ANY WHERE ON LINE. GLAD TO BE OF SERVICE
Jan 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
256 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
