Question about KitchenAid Washing Machines
I have a kitchenaid washer model KAWS677EQO and it won't drain, what might the problem be and how can I fix that?
5 Suggested Answers
  • 92 Answers
SOURCE: I have a kitchenaid washer model KAWS677EQO. I
the bearings have worn is my guess.
Posted on Jul 15, 2009
  • 441 Answers
SOURCE: need cu ft of kitchen aid washing machine
3.1 cu ft
Posted on Nov 17, 2009
  • 107 Answers
SOURCE: KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
Posted on Nov 15, 2011
richroth
  • 9472 Answers
SOURCE: kitchenaid washer won't spin and leaking oil
What is the model number of your unit?
Posted on Nov 24, 2012
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Have a KitchenAid Prestige Top Load Washing Machine (Model: KAWs677EQO). It makes noise during the spin cycle and the drum moves when it comes to a complete stop after the spin cycle. Otherwise, it works...
I had the same problem 1 month ago, its probably the motor coupling for the direct drive. Its a small rubber Ring + a plastik drive. Its easy to change and not expensive.
Here the link for the part
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
May 01, 2010 | KitchenAid KAWS750L Top Load Washer
KAWS677EQO Washer The agitator is tightly winding up the clothes and making a horrible sound. Even when we unwind the clothes and take some out it is still winding what's in there.
It sounds as though the agitator dogs are jammed. Usually they strip and don't agitate at all. Here is a picture if you can open it:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=84229&pkw_=basket&model_id=257287&NewWindow=1
The agitator dogs are number 17 on it. They are cheap ($5.15 on appliancepartspros.com) and pretty easy to change. pop off the top of the agitator, pull out the cap, remove the bolt and plate under it and you'll find the 4 plastic dogs.
Dec 31, 2009 | KitchenAid KAWS700L Top Load Washer
Washing Machines Logo
51 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
Mike
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
