Question about Panasonic Audio Players & Recorders
CD was playing, now won't start. Panasonic RC CD 500. Shows time, PM CD and Alarm1. When CD buttin pressed the time display disappears, byt it doesn't play. Suggestions please?
SOURCE: system keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
Posted on Sep 08, 2007
SOURCE: won't play a cd
put a mp3 cd it will work worked for mine has truoble reading regualr cds
Posted on Feb 08, 2008
SOURCE: My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Posted on Jun 28, 2008
the napiers
  • 11 Answers
SOURCE: Radio/Cd Player will not work/Display shows, then disappears seconds later and will not play.
if its factor bad radio is fried same goes with after market radios the only solution with out spending money to find out is to find a good used factore or get new after market your choice
Posted on May 20, 2009
SOURCE: 2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Posted on Dec 18, 2009
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
HOW DO i CHANGE TIME ON PANASONIC TELEPHONE KX-T7730
Press Program
0
you will see a display (January 19, 2011 - display 110119)
enter your date (don't press any other buttons, the phone will do in sequence)
YYMMDD
enter day of the week (1-Mon, 2-Tues, so on)
enter time (don't forget to enter 0 if like 9:30)
0930
enter AM or PM (0-AM, 1-PM)
0
then press store button
then press program button
you should see your date and time display
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Mar 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
21 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
