Question about Brother MFC 210C All-In-One InkJet Printer
Printer can't read ink levels correctly
I put in new in cartridges and followed the printers led screen instructions and closed the printer deck. In beeped a couple of times and then it said cleaning, I waited and waited then it beeped two more times and said on the led screen ink levels low. I cleaned all know contact points and tried the process again. Now it says no ink cartridges. So Now my last resort was to unplug it, and see if will reboot the printer to scan for the new cartridges. Are there any more suggestions out there to try??
  • 44 Answers
Uninstall driver. unplug printer before of after, as asked or if asked. then try to find LATEST DRIVERS for your printer from manufacturers page and it'll be done. PS also you can try, it helped me sometimes to just put the clean button on and whet it cleaned cartridges (1 test page) it showed OK ink level. Also look at the bottom of cartriges and clean them if needed. but read on net how to clean and if you can clean them. Hope helped. by
Posted on Jul 24, 2009
  • 499 Answers
Try to reset ur printer
try this
1 Press Menu/Set, 0, 2. 2 Enter the last two digits of the year. Press Menu/Set. 3 Enter two digits for the month. Press Menu/Set. (For example, enter 09 for September, or 10 for October.) 4 Enter two digits for the day. Press Menu/Set. (For example, enter 06 for 6th.) 5 Enter the time in 24-Hour format. Press Menu/Set. (For example, enter 15:25 for 3:25 P.M.) 6 Press Stop/Exit. The LCD now shows the date and time whenever the MFC is in Fax mode
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
Here are some steps can help you.
Use only New Original HP ink
Restart the printer
Rreseat the ink cartridges
Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
Restart the printer.
I hope this will be able to help you resolve the issue.
Thank you for choosing Fixya.
Mar 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Overiding Empty Cartridge error for Dell A10 962
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
321 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
