Question about LG Televison & Video
Need code for LG disc/dvd player model BPM35 to hook up to TV
    Top Expert:
  • LG Master
  • 75,452 Answers
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 24, 2017
How to hook up pioneer dvd player to a lg lcd tv
That all depends. What outputs does the DVD player have and what input will the TV accept? If compatible, just plug a cable from the DVD output to the TV input and then (on the TV) select the DVD as a source. For more specific instructions you need to include information such as the make and model of both the TV and DVD player.
Jan 28, 2017 | LG Televison & Video
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Need code for my LG blu-ray disc/dvd player to set remote for samsung digital tv
You're trying to control your LG blu ray from your Samsung remote? Hold down the power button and press 1 - try that then repeat and try 2 - go all the way up to ''20'' . Or if your manual has LG codes and they don't work - also try the codes for NEC or TEAC
Mar 01, 2014 | Televison & Video
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
Cannot hear sound from DVD
First make sure your cables are hooked up correctly. they are color coded which helps a great deal. Make sure the red and white cables are hooked up from the DVD (audio out) to the (audio in) on the TV If this does not help, make sure your cablea are good and not broken. If still no sound, I would try cleaning the disc player with a lasor lense cleaner. If this did not fix it, I would get a new player, these are just to cheap to have them fixed.
Nov 15, 2010 | LG V181 DVD Player/VCR
Region codes reset
hi juferrer,i guess the dvd u have brought is from a foreign one. Region coding is how Hollywood studios stagger dvd movie releases across the planet. These codes ensure that one country doesn't get a DVD movie before the same movie is out in that country's theatres. In their corporate omniscience, movie studios have carved the planet into regions with each region having a specific code.
All DVD players and discs have region codes. A DVD player and disc must be of the same region or the disc will not play.
If you want to watch movies from other countries, you need a multiregion DVD player. This will allow you to play any disc from any region. However, because TV standards differ, you might need a specialized NTSC/SECAM/PAL TV or a DVD player that can output any signal to the standard your TV accepts.hope u get the point.
raj..
May 10, 2008 | Audio Players & Recorders
Lg remote control codes
i have a lg monitor /tv model number M197WDL with no remote control ,so i am looking for the code to put into my one for all
Jan 08, 2008 | Televison & Video
Televison & Video Logo
74 people viewed this question
Computer Repairing
Computer Repairing
