WD40FW2610 shows please run channel auto scan then i do thes it gots up to 69 and quits
    Master:
  • 923 Answers
What about your Westinghouse 40" LED TV? What was the year of manufacture? Did they offer more that 69 cable channels on that model in that year? Not on UHF/VHF bands!
UHF/VHF: AIR (2-69); CABLE (1-135) • Composite/C-Video Input: NTSC
Posted on Apr 24, 2017
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Please run channel auto scan
NO picture just error message "please run channel auto scan"
Feb 14, 2013 | Insignia 37" LCD Flat-Panel HDTV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
