Question about Cub Cadet Garden
Cub Cadet 1515 38" cut. I have a 6 mo old battery. It was starting fine until I hooked up my headlights with a burnt light harness. Now nothing happens when I turn the key to start the Kohler engine.
    Top Expert:
  • Cub Cadet Master
  • 49,228 Answers
Check for blown ignition circuit fuse
Posted on Apr 24, 2017
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Have cub cadet rzt 50 ground wire pulled loose
green wire is a ground for the wire harness and needs to be grounded with the ground cable and it usually grounds to an engine mounting bolt or close to it
Oct 19, 2014 | Garden
Older cub cadet mower runs fine until blades engaged starts stalling out
Check that the battery is fully charged. If the water is below the top of the plates it needs topped up. If it is old it may not hold enough charge to drive the ignition and the electric clutch. The clutch can draw so much power the ignition falters and so your engine dies. The engine charger may not be able to cope with the draw off when the clutch first comes in.
Sep 28, 2014 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
