Question about Panasonic Audio Players & Recorders
Hi I have a PANASONIC RE-7176 in beautiful condition. It has PHONO, REC, and 16 OHM outputs on the back. For some reason, I can't get anything out of these ports but crackling and a hum in the 16 ohm
  • Carson Thaxton Apr 24, 2017
    Thank you for the help, I'll definitely try it some things out!
    Master:
  • Panasonic Master
  • 923 Answers
That sounds like a classic "high impedance" failure. Either the cartridge is bad (possibly cracked) or the connections are loose in the system or you have one or more bad wires or possibly an open ground connection!
Posted on Apr 24, 2017
    President:
  • 3,074 Answers
You can take it apart, look at the solder runs and see if they are cracked, if so you can re-solder. Hope this Helped Tim
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
  • 10 Answers
SOURCE: 6 ohm speakers - 8 ohm amp
This is a tough one due to the info at hand, but I'll take a stab at it.
I'll assume that your amp is not a tube-type amp. I'll also assume it is a relatively recent "solid state" design. If those assumptions are correct, connecting a 6 ohm load to an 8 ohm amp should not cause significant overheating or amplifier instability.
Posted on Jan 04, 2008
djnick989
  • 1067 Answers
SOURCE: 4 ohm speakers for 8 ohm impedence on receiver (HT)
ya cant run them 4 ohm on 8 ohm sterio run super hot then fail sooner gota get sum nice 8 ohm ones ok flouece off ebay is relly good cheap 8 ohm
Posted on Jan 24, 2008
Xtremeroofin
  • 67 Answers
SOURCE: no output to speakers
Yes inside should be 2 for the speakers and phen a power fuse
Posted on Dec 24, 2008
  • 4234 Answers
SOURCE: Marshall jcm 2000 dsl 100 head not powering cabs 4/8ohm outs
Since you are getting some output, the amp section is probably OK. There are circuits designed to handle thge difference impedence outputs. This should be a relatively simple repair for any shop that handles these units. If you don't have one local to you, let me know and I'll locate the service info and get you more specifics.
Dan
Posted on Mar 06, 2009
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    How to hook speakers up to a realistic mpa-40
    The MPA-40 is a mono public address amp. So it has one speaker output. You select the appropriate socket to suite the speaker type. The 4/8/16 Ohm outs are for various tpyes of Hi-Fi speaker. The 70 Volt is used for muzak in shopping centres, restaurants, and waiting rooms.
    If you have a pair of 8 ohm Hi-Fi speakers, you can diasy chain the connections and then use the Com and the 16 Ohm connection.
    Daisy chain means you take the wires from a pair of speakers. Connect together the wires going to red on one speaker and black on the other. This now leaves you with two wires going to the other red and black terminals on the speakers, but the ends in your hand are not connected to anything yet. Plug the black in to COM. Plug the red in to 16 Ohm.
    The sound from the speakers won't be stereo. It will be mono because that's all the amp outputs. But both speakers will work so long as they're functioning units.
    If you have two 4 Ohm home theater speakers then you can do the same trick. 4 + 4 makes an 8 Ohm load. Connect the red to the 8 Ohm output.
    Don't be tempted to try to connect to multiple terminals. The amp isn't powerful enough to to run more that one speaker chain.
    Hope this helps
    Sep 15, 2014 | Audio Players & Recorders
    Marantz pmd520
    The PMD520 doesn't have balanced XLR inputs; only unbalanced phono/RCAs. If your source has phono outs too, then use those, because the benefit of balances inputs is lost when converted to phono.
    If you still want to go ahead, then buy some balanced to unbalanced converters.
    Studiospares RED502 Bi Directional Balanced Unbalanced Converter
    If you try to do this on the cheap by wiring an XLR to phono, be aware that the studio level output of balanced level connections is about 2V rms. The live input level for unbalanced is around 1V rms. You'll either need to pad the input to reduce the level or run the cassette REC level controls nearer to the bottom of their adjustment range where they're a bit noisier and not so linear.
    Apr 28, 2014 | Audio Players & Recorders
    I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
    hi,
    yes you need an amplifier with or without phono input.
    your turntable has three types of output
    1.phono output (can connect to the phono input of an amplifier which has a phono input)
    2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
    there is a selection switch for phono or line level output on the back side
    3. and usb( to computer)
    Jan 06, 2011 | Stanton T55 USB Turntable
    I am trying to find the output power, watts?
    bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
    Jun 08, 2010 | Audio Players & Recorders
    How to wire a numarkdm1600x amp
    Power amplifiers usually has only single input RCA input left "white" right "red". The preamp has plenty of input and output jacks, the proper connection is the one labeled "PREOUT" which usually located far from the group of rca jacks "PHONO,TAPE MON. REC OUT" etc. try it, it doesn't harm anything
    Aug 09, 2009 | Audio Players & Recorders
    I have an ADC equalizer model # SS-100SL i'm
    record out-------equalizer in-------equalizer out------tape in
    Mar 01, 2009 | Audio Players & Recorders
    Connecting Pioneer SX-737 Receiver to computer problems
    I've been recording LPs for over a year now.
    I've got the turntable outputs plugged into the phono inputs on the receiver amp.
    I'm taking the Y cord (pair of RCA connectors at one end, mini plug at other) from the Tape Record (these are what you'd use to send a signal to the tape deck for recording) on the amp to the "line in" on the sound card. You may want to look up the specs on your sound card to make certain that you've got the plug in the correct socket. There may be a "line in" and a "microphone" socket. Use the "line in"
    What recording software are you using? Audacity is free and is ok. I'm using Goldwave (costs ~$50) and highly recommend it. MUCH better than any other package I've tried. Just google "goldwave" to find it.
    The recording software should have an option for selecting / specifying a source. If you have "microphone" selected and the y cord going into the "line in" socket, yoiu won't get anything.
    Dec 20, 2008 | Audio Players & Recorders
    What to use for Audio-out on Denon AVR-2807?
    Hi Karmor
    Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
    regards
    Graeme
    Mar 15, 2008 | Denon AVR-2807 Receiver
    Tv/pc
    Your Panasonic TC-26LX20 26 will only allow video inputs through the:
    1. composite video/audio input ( RCA phono x 3 ) - front or rear
    2. S-Video input ( 4 pin mini-DIN ) - front or rear
    3. component video input ( RCA phono x 3 ) - rear
    4. HDMI ( 19 pin HDMI Type A ) - rear
    Depending on the output(s) available from your PC, you can use any of the following:
    a. the yellow RCA female
    b. S-Video output ( 4 pin mini-DIN )
    c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
    Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
    Good luck and kind regards.
    Nov 17, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
