I have an E-80. Went out yesterday and it would track my location and show land masses but not tops underwater? Did I program wrong? I turned it on the same way I always have.
It showed my tracking and just a screen background of small faint dots.
SOURCE: video screen turns black and ipod freezes
hold the center button and the menu button for 10 -15 seconds.
That will reboot the ipod without harming your data.
Posted on Aug 09, 2008
SOURCE: underwater digital camera
I have the software, and the book if you want i send it to you for € 20 !
I have also a problem i can not delete my fotograghs of my camera ?? Can you help me ?
Posted on Oct 18, 2008
SOURCE: My Zen is stuck on DJ mode and Shuffle mode. HELP!
Hold down the back button until a little gray screen appears. Then scroll down to Play Mode and select normal.
Posted on Jul 12, 2009
SOURCE: Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
  • 441 Answers
SOURCE: Small white dots are showing up on the screen when
The white spots you are seeing are a result of dust or dirt in the light asm. Mits knows about this as a problem. The inside chamber of the tv needs to be cleaned. If your tv is in warranty they will come to your home and fix it. If not it is very easy to damage the tv by trying yourself, start with cleaning out the chamber that the bulb is in, use compressed air to blow out dust and dirt, them on the sides of the tv are round flaps that will need to be removed and this will go into the main mirror chamber, be careful but blow out any dust or dirt you see on the mirror. I would have a repair tech handel this unless you are skilled in this area.
good luck
Posted on Nov 13, 2010
Charting a route on water
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Jul 18, 2012 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
My land rover defender steering wheel starts to shake and wobble at about 80-90km/ph and gets worse. I have had the wheel balance and alinement done but it is still there. What other causes could cause...
This is really annoying, happens with most Defenders, but is easily fixed. It is the steering damper. They are never strong enough. Best solution is to fit an additional damper onto the track rod. Remove the track rod protection bracket from under the rear of the front diff, fit a heavier track rod and mount an additional damper on the track rod. The other end of the damper is mounted on the rear of the diff (where the protection bracket was removed). Land Rover specialists such as MR Automotive in Brisbane will send you the required parts. You won't regret doing it!
Dec 02, 2010 | Land Rover Defender Cars & Trucks
Land cruiser vx turbo diesel 1990 80 series.
Track down Toyota publication RM184E - a search of the ih8mud forums is a good start to finding it.
Mar 12, 2010 | 1990 Toyota Land Cruiser
Track Eraser Deluxe
Goto control panel, click on clasic veiw on the left hand side of the window, double click on programs and features or add/remove programs depending on what operating system your are using, find the program you want to unistall, just right click on the progam and the options for that program should show up, click on the option desired.
Feb 01, 2010 | Computers & Internet
White balance and blur underwater
You are not doing anything wrong with your white balance, white balance is very difficult under water, and you should be careful, because your mask might be tinted a certain color, I reccommend leving you white balance normal, then adjusting in photoshop, take a white object down there and hold it over a non important part of the picture, to help with adjusting in photoshop, then crop the object out of the final image. Focusing underwater is difficut as well, as dater distorts light, there is nothing that you can do to keep the water from distorting the light, but if you go to apeture priorities, you can increase your apeture to between f7.2 and f11 to reduce blur (to keep the picture from being too dark and the shutter from being too slow, you can increade your ISO)
Jul 28, 2009 | Fuji FinePix F100fd Digital Camera
Broken track
I have the same problem. I contacted Olympus and it is 29.95 plus tax to repair. Right now I am getting around the problem by holding the cover and controlling it as I open or close to make sure the camera turns off and on.
I purchased a second reconditioned camera from Olympus on the auction site for $35.00 and it arrived yesterday.
It comes with everything except a remote. The battery is the newer L12B. Considering the cost of a replacement OEM battery and the camera looks new, it seemed to be the best work around to having the camera repaired.
I keep it because I have the underwater case for this model and to buy a case for another camera is big bucks..
Jun 28, 2008 | Olympus Camedia C-50 Zoom Digital Camera
Th1101A Sound Distortion
The headphone jack itself could be bad - time to replace.
Mar 13, 2008 | RCA TH1101 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
