Question about Dryers
My super works 2HDD electric will not start just buzzes when I turn on?
    Top Expert:
  • Dryers Master
  • 50,008 Answers
Check /replace the start/run capacitor for the motor
Posted on Apr 24, 2017
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
When you push the start button the dryer buzzes and never clicks over to start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Super...
My dryer belt started slipping. then it would not start when I pushed the start button, it makes a buzzing sound but won't start. I know I need to replace the belt, but what would I need to replace...
heatman101
Aug 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer is making a buzzing sound
heatman101
Mar 19, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My 99 4x4 6.8l f250 Super Duty Service engine soon light came on code is p0500 rough shifts idles high stalls speedo isn't working replaced rear abs sensor last time it happened worked fine this time...
There is a speed sensor which will give off this code. It would explain why the speedo is not working. For the trailer light relay, I would agree with you about the water issue. For that problem you need to start eliminating power to the plug because something is backfeeding up to the light relay.
If you have an Electric brake controller see if you can shut that off and if the buzzing goes away you know you are shorting out through the wiring or plug. Probably for the amount of time it takes to trace down everything you are going to be unwrapping, the wire loom and splicing in another wire anyway. Why not just replace everything from the trailer plug to the cab and be done with it for years? With what you have now the best you can do is patch in a new wire: they don't really give you enough slack to put on a new plug.
Mar 10, 2011 | 2008 Ford F-250 Super Duty
Onkyo tx-sr606 receiver buzz
This kind of noise can be caused by a transformer that was poorly made. Iron core transformers are normally 'potted' in a vacuum so that epoxy (or lacquer) is forced into the laminations to prevent them from trying to vibrate with the line frequency.
If you are adventurous, remove the housing, turn on the power and using an insulating probe such as a plastic rod (a plastic picnic knife will work), place the tip of it on any larger parts you see and place the other end behind your ear. This will carry the sound in a more directional manner to your ear. You should be able to locate the source of the buzz.
If you can, and it turns out to be a transformer, it will probably have a metal shield around it so it might not be possible to gain access to the laminations. If the shield isn't ultra tight, you might be able to flow some 'Super Glue' into the cracks and with luck, 'glue' the laminations together. Super Glue (or equivalent) is a good insulator so will not cause any electrical problems but take care not to get it on any plastics that are exposed with the housing on, it will cloud them forever.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Buzzing noise! when the
sounds like you have a problem with the water solenoids (the electronic controlled water valves) the buzzing is an indication that it is trying to open or close and unable to do so. an electric current creates a magnetic field pulling a spring loaded valve sealed inside a tube allowing water to pass. it starts buzzing when it can't pull the valve all the way and just vibrates.
May 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
Dryers Logo
Top Dryers Experts
