Model mc202-135050 AC charger - Computers & Internet
Is the charger 24 v ac or is the charger ac that converts to 24dc before entering jumpbox?
If you look at the charger (the plugpack which goes in the wall socket) it should have on it a small rating plate saying what is the output. However without a make and exact model number we can't say for sure.
Dec 31, 2015 | Computers & Internet
I lost my charger , where can I find another charger in Phoenix Arizona?
It is not required to use a charger for charging the NWZ-E438F Walkman Player. You can connect the Player to the Computer using the USB cable for charging the Walkman Player. The charger is not supplied with the Player, however you can purchase the portable charger for the Player.
Recharging Time : USB-based charging Approx. 4 Hrs (full charge), Approx. 2 Hrs (approx. 80%)
The model # of the compatible charger is AC-U501AD and AC-NWUM50. Click here for the link to purchase AC-U501AD and AC-NWUM50
Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Jul 17, 2011 | Sony NWZ-E438F Digital Media Player
Ineed an ac charger magelan gps model 1412
Incredibly, the AC charger for your GPS is incredibly inexpensive.
I found a link where you can purchase them for a very good price!
Hope this helps.
Aug 22, 2010 | Magellan Car Charger Power Adapter Cord...
Xantrex Inverter/Charger has no AC output
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
I have lost my ac charger for my VEC013DB 400 amp
You can find that part on Dewalt - Black & Decker website - they make 2 different A/C chargers for that model.
This is the link to their website:
This is the part number for the 12v - 500ma AC charger: 5140045-42
This is the part number for the 12v - AC charger with the barrel pin: 5140045-34
They run about $14. on their site.
Oct 13, 2009 | JUMP START SYSTEM
Magellan 1400 gps does not turn on when connected to car charger. Tried several times but in vain? can you let me know how to fix it?
well it may not be able to be solved without expense.
Do you have an AC charger? if so try to turn iot on when its been connected to the charger for about 10 mins if it comes on when on AC then you will need to change the internal battery/s other than tjhat the circuit is damaged
some models do not have AC chargers
if this is new or under warranty make a claim ASAP as they go out of models so quickly they have a poor warranty system
Jun 23, 2009 | Magellan RoadMate 1400 Car GPS Receiver
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
I have a sony cyber-shot DSC-W35
You need AC charger of following number...
It is available in Sony Accessories (please type model number of camera and check results)
Dec 17, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
I need to order a whole set of new cables
copy and paste the following link - this item is on ebay:
Jan 11, 2008 | Durabrand PDV-705 Portable DVD Player
Computers & Internet Logo
David Payne
David Payne
