Do you have a transformer for my unit listed? 120 vac 60 hz 14w. output-13.5 vdc 500ma class2 transformer
    Top Expert:
  • Audio Player... Master
  • 48,384 Answers
fixya site doesn't sell anything
Posted on Apr 24, 2017
Coleman Powermate 5000W has HIGH RPMs until a 3KW load
This generator is less than ideal to use as a home unit. see and look at residential videos. Basically the voltage is governed by a capacitor on your unit, and ouput is directly propertional to speed. Also the engine is mechanically governered versus an electronic system. This is a common mistake using portables to power home equipment. You will damage your home digital equipment, do not use recommended
Jan 25, 2013 | Coleman Powermate Powermate 5000W...
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
90/180 volt output is ruining/overheating tools and several electronic devices and fluorescent fixtures will not start.
I am not familiar with this make of generator, however I am thinking that voltage regulation and rpm are tied together with this unit. The generator MUST have an output of 60 hertz. This could be 63 hz (when the load comes on it drops to around 60). If the frequency is NOT at the above specs you will burn out anything with a transformer or motor. Now this translates to around, minimum of 3600 rpm on the engine. If you have access to a frequency meter (a kill-a-watt) you can set the speed. I found it best when using the kill-a-watt to use it with a minimum of a 10 foot extension cord. Set the throttle speed so that your frequency reading is 63 hz. If this is the non electronic voltage regulated type of generator, the voltage should come up to around 120 volts and the frequency should be at 63 hz.
Mar 09, 2011 | Northstar Generator 13 Hp, 8000 Watt,...
Will a UK SONY KDF - E50A12U LCD Projection TV work in the USA?
In the United States we have one flavor of electrical power. That is 117 VAC (Volts Alternating Current) at a (alternating) signal of 60 Hz.
Hz stands for a man named Hertz who discovered the phenomena of frequency in the 19th century. It was originally was called "cycles per second" but has been renamed long ago.
The UK uses 220 VAC at 50 Hz which is a different flavor of electricity.
Since Sony (as do most manufacturers) produce sets for the differences in regional use your set simply won't work in the U.S. There are transformers available to convert 220 VAC to 120 VAC (Your set draws 210 Watts when it's on and 17 W when it's off. That means you need a fairly heavy duty transformer to make the change. Unfortunately because your set was set up to work with 50 Hz (it is branded as a British production set)
I wouldn't risk operating it at 60Hz which is the type the U.S. uses. Besides that your tuner is designed to receive a different format video than the United States uses.
Apr 17, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
What is the proper DC power supply voltage for an
Power supply details are as follows:
Mar 12, 2010 | Visioneer OneTouch 8100 Flatbed Scanner
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
Power supply
May 24, 2009 | Visioneer 4400 Flatbed Scanner
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
27 people viewed this question
