Question about LG Cell Phones
When attempting to type text into the calender two small blue indicators show in the upper right "en" and "T9" I can't type characters in for a new schedule that I want--it types jibberish. How do I get it out of this mode?
How do I use alphabet keys on remote
Generally, entering text is carried out the same way as with most cell phones.
  • 0, 1, 2, 3, 4, 5, 6, 7, 8, 9: Enter a character to the position pointed by the cursor.
    • First press: enter the first character from a set of characters related to this button. Each subsequent press: you may change the entered character to the next one from this set.
    • 0: enter the space.
    • 1: enter a special character (punctuation marks, etc).
      • Up, Down, Left, Right after pressing 1 (special character entering mode): select the required character.
  • ENTER: confirm selection; finish text entering.
  • SUBTITLE: enter the period (for numeric mode); functions like button 1 (character mode).
  • CLEAR (<-): delete a character to the left of cursor.
  • SELECT (cap'num): switch input mode:
    • abc: character mode, small latin letters.
    • ABC: character mode, capital latin letters.
    • 123: numeric mode, digits.
  • RETURN: cancel the text changes and finish text entering.
  • Left/Right: move the cursor one character left/right.
  • Up/Down: move the cursor to the start/end of a text line.
    • If the cursor is already in start/end position: select another user interface element which is under/over the current text entry area (only for dialogs with several elements of user interface; text changes are confirmed automatically).
  • POP UP MENU: show context menu with a list of available commands. They allow you to cut, copy and paste text using the clipboard, much like it is done on a PC.
  • http://electronicshelponline.blogspot.com/
Jun 26, 2016 | Televison & Video
Why is my brand new Alcatel phone putting in strange symbols when I send a text if its more than 160 characters?
My Samsung cell phone limits me to 140 characters so this is not unheard of. I split my messages to under 140 and ask people who need to write a veritable epistle to do so by email because my phone cuts vital pieces when it chops messages up on receipt.
Jul 03, 2015 | Alcatel Cell Phones
Accessing the upper right characters
hold the f and type the and type the character you want
Mar 22, 2014 | Smith Corona Typewriter XD5900 Refurbished...
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do i get the t9 off my text messages on a samsung d900???
ABC, T9, Number, and Symbol modes
You can enter text in some features such as Messages,
Phonebook, or Calendar, using ABC mode, T9 mode,
Number mode, and Symbol mode.
Changing the text input mode
• Press the right soft key to change the text input
mode.
• Press and hold [ ] to switch to Number mode.
• Press and hold [ ] to switch to Symbol mode.
Using ABC mode
Press the appropriate key until the character you want
appears on the screen.
: ABC mode : T9 mode
: Number mode : Symbol mode
Apr 07, 2010 | Samsung SGH-D900 Cellular Phone
Blackberry Locked Up
Hi there;
Looks like you either forgot your password or not typing the password in correctly. I have done that many times - I found when using the multiple character keybord i was typing the wrong character. Double check what you are actually typing in.
So, the message means the device will reset as in it will wipe all the data to standard settings after 6 attempts.
Just a protection system on BB's. Your device will perfectly fine once your device resets and you can enter a new password :o) but you will loose all the data like emails/txts/calender/notes from the device.
I hope this Helps,
Thanks.
Feb 17, 2009 | RIM BlackBerry 8700g Smartphone
Cant text in t9 mode
a master reset of the phone will help
Nov 24, 2008 | Motorola Mobility RAZR V3
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
SMS problems - Imate PDAL
I am assuming you are refering to T9. To turn it off you need to do the following:
When in new message screen.
Press the right soft key and a list of modes should appear.
Pick ABC mode for regular typing.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 19, 2008 | i-mate PDAL Pocket PC
T9.
To activate T9, undertake the following steps:
Messages
New text Message
Press the first button from the right on the last row
Go in the option T9.
Choose 'On'
Nov 21, 2007 | LG Prada KE850 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
