Question about Microwave Ovens
Overheated my microwave oven - thought I was using the timer but I set my oven for 65 minutes. It shut off - no lights inside & no power now
fridgetech
  • 473 Answers
SOURCE: Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Posted on Feb 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: overheated microwave
Hopefully the magnetron thermal cutout or thermostat protected the magnetron from destruction!
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 26, 2008
SOURCE: Microwave turned on but nothing inside to cook, so now it's dead!
Put him up for adoption before he burns down your house.
Posted on Jan 29, 2010
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
I have a GE Profile Model #JE1860SB001 serial #MV903523K. In error I set the cook time to 60 minutes (thought I was setting timer to 60 min.) & it overheated - melted an empty polyethylene cup which...
The magnetron may or may not have been destroyed, but at the very least the thermostat on the magnetron probably was.
Its job is to interrupt power when the mag gets too hot, in order to stop the heating process with the aim of saving the magnetron.
There is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Dec 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
No power to Control Panel Jenn-Air JMV8208AAS
This can happen if one runs the microwave empty instead of user the timer function or if the internal cooling fan fails or if the magnetron is going bad.
Chances are it overheated and the magnetron's thermostat / thermal cutout has failed.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, and troubleshooting tips.
Most computers will open this document automatically, but you may need the
free Adobe Reader.
Aug 04, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Microwave may have overheated
There are two thermal protectors which may be blown. If so, it will measure open (infinity) instead of closed (zero ohms).
One is located on the magnetron and one is on top of the oven cavity.
(There is also one located on the floor / base of the microwave but that one's not at issue.)
The magnetron thermal protector *may* be accessible by removing the control panel, but to access the oven cavity thermal protector, you will have to remove the oven from the wall.
If so, the installation instructions here are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 23, 2009 | Goldstar MV-1515 Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
Vent Fan Will Not Shut Off
The vent fan TCO is a normally open type. I would say you replaced it with a normally closed type.
Probably the only TCO that was bad would have been the magnetron TCO.
If you still have the old vent TCO, I'd reinstall it.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
We have this old Radarange Amana MICROWAVE from the 70's and dont quite know how to use it.
Normally the dials are the timer for cooking time plus cooking power level dial, for defrost, medium, high, etc.
It may also have a start button to start it cooking. If not, then you place the food inside, shut the door, then rotate the timer dial to however many minutes you want.
If this does not answer your question, maybe you can take a photo of the controller and post it.
Jun 04, 2008 | Amana Microwave Ovens
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
