Question about Dryers
My ceiling fan directional switch fell to pieces... could this be the reason why my ceiling fan is not spinning? I replaced the capacitor and still nothing...
4 Suggested Answers
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
  • 14 Answers
SOURCE: where does while lead from ceiling connect? capacitor has five leads, 2 gry, 1rd, 1 grn 1br, (grn gry br to switch) switch has black lead to ceiling lead.
White is the common, or neutral. There should be a white wire to connect it to.
Posted on May 24, 2009
lkjtgbvw
SOURCE: the ceiling fan spin was slow. The c61 e185116
Hi, replacement capacitor can be found at amazon. Take a look here: Amazon com c61 capacitor 4 wire. I hope this was helpful. cheers
Posted on Dec 06, 2014
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    My ceiling fan is spinning in the WRONG direction. I know because I have an identical fan spinning in the right direction. How do I get my fan to spin in the right direction? It has been doing this ever...
    shut it off, an get up there and see if it has a directional switch, to make it go forward or back wards. also be sure the blades are not upside down on fan motor. the reverse switch should be on the fan motor housing so it can be reversed.
    Sep 09, 2010 | Hampton Bay 52 In. White Redington...
    The ceiling fan spin was slow. The c61 e185116
    Jun 22, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
    Fan
    If the fan is running at all, you have the capacitor connected properly. Without the cap the motor won't start up. There are only two wires to the cap, and it doesn't matter which one goes to which lead on the part. As long as you connected the same wires that went to the old one to the new one, you did it right.
    Most likely, when you had the fan apart to replace the cap you bumped the "winter/summer" switch and reversed the fan direction. Just flip that switch and the fan should be back to spinning the way you want.
    Apr 13, 2010 | Aloha Housewares (93645) Ceiling Fan
    Ceiling fan will not spin, but I hear it
    It most likely has a faulty capacitor not allowing it to start. Remove the light kit or the cap where the light kit mounts, the speed and reversing switch will be in there along with a capacitor. You should be able to buy a replacement capacitor at most home improvement stores.
    Sep 30, 2009 | Dryers
    Ceiling fan won't blow any air
    if its turning its either sucking or blowing air. There is a switch or a pull cord to reverse it. prove it to yourself with something light like a feather or piece of paper or balloon.
    Aug 16, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
    Fan switch broken
    replacement switches at home depot for 3 speed fans.There should be instructions on the package of the switch.
    May 07, 2008 | Hampton Bay 04379 Madison Avenue Ceiling...
    Hampton Bay Ceiling Fan At Slow Speed
    I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
    Aug 10, 2007 | Hampton Bay 52 In. White Redington...
    Dryers Logo
    27 people viewed this question
    Top Dryers Experts
