Question about Fossil Watches
I need to know what my watch is worth. Its a Fossil Arkitekt, Model Fs-4166
SOURCE: I have the Fossil FS-4154,
Did you put the protective cover back over the battery? sounds like a grounding problem.
Posted on Sep 22, 2008
escapement
  • 2334 Answers
SOURCE: REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
SOURCE: can't find the watch band for fossil arkitekt fs
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
Posted on Jan 28, 2010
gemineye61
  • 831 Answers
SOURCE: I don't have the original battery to my watch, and
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Posted on Aug 24, 2010
Where could I find an owners manual for Fossil Arkitekt FS-2934 ?
Try Googling (fossil)(FS-2934)(manual) without parens.
Jul 17, 2017 | Fossil Watches
What kind of battery does the Fossil arkitekt watch FS 2905
Find out by removing back, finding battery, and identifying type.
Dec 02, 2016 | Fossil Watches
What battery size does a fossil arkitekt fs-2759 take? Thank you
Just take the watch to your nearest jeweler. They can quickly replace it for you....probably cheaper than what you would pay for the battery yourself.
Mar 02, 2015 | Fossil Watches
How do i set the month on my fs-4250
Google (fossil)(Fs-4250)(manual) without parens for month setting instructions.
Sep 14, 2014 | Fossil Arkitekt watch
What battery goes in the Arkitekt Fossil FS 4313
Take your watch to a jeweler for battery identification and possible replacement.
Sep 12, 2014 | Fossil Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
Aug 24, 2010 | Fossil Watches
Fs 4159 sudennly stopped working
The first thing to check is the battery.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 25, 2010 | Fossil Arkitekt watch
Can't find the watch band for fossil arkitekt fs 4127?? it have a curve and use two pins
Jan 03, 2010 | Frontgate Watches
Watches Logo
26 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
