Question about Craftsman Garden
I swaped engines from a 98 Koehler vpro 20 to an 03 lt2000. The pig tails are the same except wire colors,can I acess wiring diagrams or can you help, please?
03 mod.247.289050, ser.1b050b70247. (Briggs and Stratton 20 hp.) 98 mod.917.272248, ser.100102a001635. (Koehler 2cyl. Vpro 20) both are craftsman 42 inch decks
mickey813
  • 472 Answers
SOURCE: Poulan 42-Inch Steel Deck 17.5 HP Briggs &
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Posted on Sep 30, 2009
SOURCE: I need a wiring diagram for a 28N777-1194-E1
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=28N777-1194-E1
There you go manuals diagrams the lot.
http://www.tulsaenginewarehouse.com/drawings/
http://www.tulsaenginewarehouse.com/drawings/allwiring.pdf
ALL wiring B&S engines above..
Posted on Apr 03, 2010
Testimonial: "Thanks for the links. Just exactly what I was looking for."
  • 146 Answers
SOURCE: 10 A Fuse blows each time I shut off engine. Short
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Posted on Jun 10, 2010
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
SOURCE: How much oil does my craftsman riding mower hold? ...
4.5 pints with filter or 4 pints without
Posted on Sep 26, 2010
What wire from the engine harness grey or brown goes to the blue signal wire on the 02 sensor
posted now 3 times.
no engine stated (of the 3)
no symptoms stated. or job.
front or rear , oBD2 sensor not stated.
on your other post, i answred for all 3 engine
front 02 sensor B1S1.
all 3 engines, the ECU schematics on the 02 pins.
go back and read. your other posts.
Feb 28, 2016 | 1997 Geo Prizm
I have an 03 S10 and i'm putting a pig tail on it and I know the yellow and green wires on the truck are the turn signals,but what are the other 3 for two are brown and I don't remember what color the
There are 2 brown wires light brown is for the fuel gauge darker brown is tail lights the other wire if it's black is ground if its red it could be power for electric brakes
Mar 14, 2013 | Vehicle Parts & Accessories
My 2003 Durango has an after market trailer hitch on which the wiring converter has literally exploded leaving me with no tail lights and fried wire ends on the vehicle side of the converter. Since I am...
You should not have to rewire anything.
Hitch wires are just "pig-tailed" on to the original vehicle wiring. Just cut off the hitch wires cleanly and tape the cut end.
You have probably burned out the stop and tail lamp fuses also. Read you owner manual for fuse location.
Please rate is answer by checking the "Hands" below. Thanks j
Feb 09, 2011 | 2000 Dodge Durango
1997 Chevy Lumina, I replaced the passenger side power window motor due to the factory one failing, The person before me cut all the wires going to the motor and toggle switch in their attempts to fix /...
There is a wiring harness on hinge side of passenger door correct, take a look at the wiring colors. Hope you can read it. At the window switch, the outside wire on either side is voltage or ground depending on which direction, up or down, reversing motor. You don't need the window switch for testing, you should be able to operate from driver door master switch. If you get the wires reversed, the only thing that will happen is, up will be down and down will be up, if that happens, reverse the wires. Just my opinion.
At the window switch, top middle wire is lockout, so only the driver can operate the windows.
Apr 26, 2017 | 1997 Chevrolet Lumina
I have a 2001 winnebago with ford f450 engine with no tail lights
oh by the way what engine does it have v10 or diesel or even a v8
Apr 04, 2010 | 2001 Ford Super Duty F 450
I need to know which wires on the new pig tail wire in the the old harniss they are different colors but they both are marked a b c d so do i match colors or do i match a b c d can you tell me or show me...
Your best bet is to go to mitchelldiy online and get the wiring diagrams. Not knowing what year your car is and what harness or computer or component your talking about and since the wiring harness may not be the correct one for your application I would be hesitant to give advice that could ruin a computer if hooked up wrong.
Mar 22, 2010 | Cadillac STS Cars & Trucks
Need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Apr 12, 2009 | Dodge Dakota Cars & Trucks
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
