Question about Radio Communications
Lost my phone connectivity when I try to connect to Bluetooth it says Pairing active enter code 0000 into device how do I do this
tat4u
  • 520 Answers
SOURCE: blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Posted on Feb 22, 2008
  • 13 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
SOURCE: HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Posted on Aug 29, 2011
  • 28 Answers
SOURCE: Need the pairing code for bluetooth device to my Altec Lansing
0000
Posted on Aug 01, 2013
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
No pin number
You must put in pairing mode first. Starting with it powered off, press and hold the Multi Function Button (MFB) for some 8 seconds (i.e. much longer than the time required to turn it on), until the indicator light is solidly lit. Then, make your phone (generically speaking, the bluetiooth device you want to pair your headset with) search for new devices. After a while your headset should appear on its screen. Select it make it connect. If a pairing code is requested ,enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode (its light blinks periodically). The pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections should be achieved simply by bringing both devices within reach. If a bluetooth link is not established, a simple press on the MFB should get the job done.
Hope it works for you.
Regards, Carlos
Jun 07, 2010 | GN Netcom GN-6210 Consumer Headset
Seal handsfree not pairing
with the phone's bluetooth active
press button to turn the seal device
press blue button on seal device
on phone, select pair new device
when the seal device is found, use code 0000 to pair the phone to the device..
next time you connect, turn on the phones bluetooth and the seal device. press blue button on seal device. it should automatically pair.
Sep 15, 2009 | Handspring Visor Prism Handheld
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
