How to set Seahawks clock, time, date temperature
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
Kewyn
  • 103 Answers
SOURCE: my solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
Posted on Nov 09, 2009
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Posted on Mar 14, 2010
dekdunn
  • 3 Answers
SOURCE: I have inherited a hifisonic
Buy another Brand with Instructions
Posted on Jul 04, 2012
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Mar 31, 2012 | Audio Players & Recorders
I have a DATEXX DRC-605 Exactime clock that just changed the date to two days ahead for some reason. How can I change it back to correct date?
Please follow these steps:
* Press and hold MODE button for 3 seconds: the year digit will flash.
* Press UP ( + ) or DOWN ( - ) to change flashing digits.
* After the first value is set, press MODE button again to confirm and move to the next parameter.
* Continue setting month, date, hour, minutes and temperature display format.
* Press MODE button for the last time to return to the time of day with seconds, after the last parameter is set.
I hope I could help.
Thanks.
gylacz
Aug 22, 2011 | DateXX DRC-608 Clock Radio
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Manual Information/Owner Guide
Also,
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
Want to set the clock
Each time you press the set button on the back it selects one of the items that you can set. For example if the "month" is selected by pressing the "set" button then press the "+" key to change it from 1->2->3->4 etc. Each time you press "+" key the month will go up by one. Stop when you reach the correct month. You can do the same for each item including the time zone and daylight savings time and whether you want your temperature to be in Celcius or Farenheit. Hope this helps...
FixerUpper
Sep 15, 2007 | SkyScan 86709 Atomic Wall Clock
24 people viewed this question
 Grubhead
Grubhead
