Need to actavaiite card - Computers & Internet
Memory card error
The GR-DF570 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot it's electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
If you need a manual, you may download a copy here.
Sep 07, 2012 | JVC GR-DF570 DV Digital Camcorder
Need digimax 200 smartmedia tm card
for clarification you need to know where you can get or buy a tm card, right?
Sep 10, 2008 | Cameras
How to install Pci-e 16x in a pci slot
Do not put a PCI-e card in a PCI slot. It will not fit and the card won't work. The PCI card has 58 or 60 pins on each side with the slot (62 pins would be present if not for the key notches for alignment). PCIe 16x cards have 32 pins.
There are adapters to put a PCI card in a PCIe 1x slot (will fit any PCIe slot) or a PCIe1x card in a PCI slot. See http://www.amfeltec.com/index.php for a sample of the adapters. For the PCIe 16x cards, you need a new motherboard.
If you are placing a PCI-e 16x card in a PCIe 16x slot or a PCI card in a PCI slot, then open the side of your case. Locate the matching slot (remove the current card) or an empty slot depending on your motherboard. Depending on the case, you may need to remove a screw to remove the old card. Wiggle the card straight up to remove it. If you are putting in a new card, you will need to remove the cover from the slot. (For some larger PCIe 16x cards, you need to remove the adjacent slot cover as well.) Some covers just pull straight up or pry a lever up and then pull; for others, you will need to use a screwdriver to break the cover out. Make sure there is sufficient room near the slot for the card. (You may need to move other cards around.)
Then line up the card so that the back of the card will fit into the opening and the contacts on the bottom of the card are above the center of the slot. Firmly press the card down into the slot without changing the alignment. You may need to wiggle it (press down on the back and front, alternatingly). Then make sure the card is fully seated. Attach the addtional power cord from your power supply, if needed for a PCIe 16x card.
Close your case. Then if this is a new video card, turn on the computer and enter the BIOS (press F1, F2, F10, Esc depending on the machine). Disable the on-board video. Then reboot the computer and load the drivers you need for the card.
I hope this helps.
Oct 16, 2011 | Computers & Internet
CAMERA READING CARD ERROR
Check if the card is defective by inserting it into another camera or a USB card reader or built-in card reader in a computer. If card is defective, and you need to recover data, you may need to send it to a company that recovers data from corrupt cards. If there is no data, you can try erasing/reformatting the card. If the card reads OK, then you may need to clean the contacts in the camera. Remove the batteries and use denatured alcohol to clean the contacts where the card gets inserted.
Oct 06, 2011 | Cameras
I need tv card drivers for itech tv card and fm card
what OS your using? if your using windows 7, try use the cd installer windows vista driver and it will work 100% sure.
Apr 11, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Hi, my display card on a acer aspire t310 died. Which card do i need to get? AGP PCI-e?
AGP video cards are the best and latest generation video cards. Depending upon your requirements, especially it you play games that have high graphics requirements, go for the G-Force graphics card with as much video RAM as possible. Check out the various G-Force graphics cards.
Sep 10, 2009 | Acer Aspire T310 PC Desktop
Fuji FinePix z10fd does not come up as removable disk on PC
The camera cannot be used as a card reader. You'll need an actual card reader to write to the card. Yes, it's confusing. You can read the card without a card reader, but you need a card reader to write to the card.
Jun 22, 2009 | Fuji FinePix Z10fd Digital Camera
Need Audio Card for PC Desktop Compaq Presario S5100 NX model
well, i need to download the sound card how to download threw internet
Oct 07, 2008 | Compaq Audio card Sound Card
Need driver
I NEED CMI9761A AUDIO DRIVER
Mar 30, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
