Question about Air Tools & Compressors
I have craftman compressor model# 919.165400 which has a bad regulator. Company don't make one anymore, do I have any alternate to this because I need air flow regulated for different usages.
  • 15,557 Answers
You can use any regulator that you want, the only difference is the new ones don't support a double gauge assembly.
Posted on Apr 24, 2017
    Master:
  • 923 Answers
I have a 02 park ave.. my voltage odes not stay steady,,, it ranges fro 13.7 to as low as 10.5,, which sends a fault ,, that shows MAF is bad,, then when I get the engine to idle,, and the voltage is...
It sounds like you may have a bad voltage regulator. On some models the voltage regulator is inside the alternator so it may be bad. Normally when you turn the AC on there is a circuit that brings the engine idle up a bit to compensate for the load of the compressor, that too may be malfunctioning. Did you look up your vehicle on the internet to see if this is an issue with that particular model?
Sep 14, 2014 | 2002 Buick Park Avenue
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 1HP/7 1/2 gal. Craftman air compressor( about 20 years old). I was using it to spray paint lawn chairs. The compressor stopped. I was to use it the next morning but for only a short time and it...
1) Check that it is not already at full pressure
2) Check that you have power coming in to the switch (20 year old power cord)
3) Bypass the switch and, briefly, plug it in.
4) Look for a fuse or breaker.
5) With the motor leads disconnected from the switch, check that you have resistance across the motor (0 ohms would be bad).
If you are not comfortable doing any part of this, don't. Check with friends & neighbors for a reputable local appliance repair company.
Jun 13, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
25 lb oil free air compressor craftman not building pressure
most likly the regulator is no good, some can be serviced, some are sealed units.
Mar 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Compressor won't build psi above 30,is this typical of the regulator or pump? the compressor is a 3 gal craftman about 1 yr old.
sounds like the regulator is faulty, normal running air should reach 110 psi, this will allow you to run tools...
Jan 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Alternator tests good, replaced anyway, still wont charge,not a conectivity or battery problem, what else could it be?
if like you say not a connection problem, then either the battery has a bad cell or the alternators regulator is bad, years ago you could adj voltage output on regulator, not anymore,due to sealed batteries
Oct 18, 2009 | Cadillac Brougham Cars & Trucks
Compressor runs for few seconds then stops think presure valve/diagphram on oil tank ?? is valve available ? not sure of model year aprox 1982
What kind of compressor is this?Air?If so pressure regulator is bad,or needs adjusting.I don`t no about a oil tank with a diaphram.
Oct 17, 2009 | Air Tools & Compressors
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
I have a craftman oiless air compressor model # 919153210 that I need parts for and sears do not carry the part anymore. thank you for any help., gcmac@netzero.net
Many of Sears oilfree compressors were made by Devilbiss. Try going to this address http://www.devilbissparts.com/ and enter your sears part numbers. (example cac-4281 for valve plate) They will most likely have the parts that you need. Good luck and email if you have other questions about your conpressor.
Feb 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
118 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
