Question about Target Office Equipment & Supplies
Wont score 1000's on targets on field or on reels
Gottleib target alpha
luisrobles
  • 25 Answers
SOURCE: The 'target' section is stuck
Hi:You try to tap at least the four or five times in the white screen?? When you want to go to the main menu, press and hold the center button.
Posted on Oct 15, 2008
  • 133 Answers
SOURCE: battery changed but wont give yardage reading
I see this happen to units that are 7+ years old. Sometimes when the battery is allowed to die inside the rangefinder this erases the programming. If the unit is this old its probably been discontinued and no parts are available. They will offer you a newer rangefinder at 30-40% discount. Call them....800.423.3537 and see.
mr tech geek
rate!
Posted on Jul 02, 2009
SOURCE: Wii Sports Resort:Archery - secret target location?
Search for the water melons!
Posted on Sep 25, 2009
SOURCE: i found message ' tap the centre of the target
Hello!
Dont worry about it , it's just the calibration wizard.Tap the centre of the target (the cross) with the touch pen (you'll have to do it more than once befor finishing the calibration)
Posted on Nov 04, 2009
SOURCE: find eGear by Target tv remote codes
need code for e gear tv for remote
Posted on Feb 05, 2011
What is the passing score for PMP Exam?
The existing PMP exam format includes the following topics along with percentage questions asked::
I. Initiating 13%
II. Planning 24%
III. Executing 31%
IV. Monitoring and Controlling 25%
V. Closing 7%
Total 100%
Total Number of Scored Questions 175
Total Number of Unscored (Pretest) Questions 25
Total Number of Questions 200
PMI incorporates qualitative scoring system. It means that they do not provide a numeric score for the exam, rather they give you a proficiency level (Above Target, Target, Below Target, Needs Improvement) for each domain. Passing the PMP exam depends on the proficiency levels you achieve in different sections. For example: If you score MP in all domains, you'll pass.
If you are looking forward to PMP certification, you must enroll yourself with a training partner, whose expert guidance can help you gain knowledge and crack the same.
Find more information here:
Managed Learning Services & IT Training
Feb 05, 2018 | The Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
I compete in 3d archery so I bought a new rangefinder 2 days ago and it reads 19.2 yards at exactly 20 yards is there a way to adjust it to read properly?
Page 5 of the manual states: RANGING ACCURACY The ranging accuracy of the Scoutâ„¢1000 is plus or minus one yard / meter under most circumstances. The maximum range of the instrument depends on the reflectivity of the target. The maximum distance for most objects is 650 yards / 594 meters while for highly reflective objects the maximum is 1000 yards / 914 meters. Note: You will get both longer and shorter maximum distances depending on the reflective properties of the particular target and the environmental conditions at the time the distance of an object is being measured. The color, surface finish, size and shape of the target all affect reflectivity and range. The brighter the color, the longer the range. White is highly reflective, for example, and allows longer ranges than the color black, which is the least reflective color. A shiny finish provides more range than a dull one. A small target is more difficult to range than a larger target. The angle to the target also has an effect. Shooting to a target at a 90 degree angle (where the target surface is perpendicular to the flight path of the emitted energy pulses) provides good range while a steep angle on the other hand, provides limited ranging. In addition, lighting conditions (e.g. the amount of sunlight) will affect the ranging capabilities of the unit. The less light (e.g. overcast skies) the farther the unit's maximum range will be. Conversely, very sunny days will decrease the unit's maximum range.
The difference you are experiencing (20-19.2=.8 yards) is within the device ranging accuracy of 1 yard, and is in fact an error of only 4%. That is pretty accurate
In case you have lost your manual, you can download from here:
http://bushnell.com/getmedia/1761b4a2-f4d9-45f7-b1d3-1e400fead84a/REVISE-20-1932-20-19426LIM.pdf?ext=.pdf
Good luck with your device.
Jun 05, 2015 | Bushnell SCOUT 1000 Rangefinder
Is there a reset option for the Yardage Pro 1000. it displays the target rectical but does not aquire a target or give a range when I depress the fire button the word laser appears the displayed find...
The laser lense or receiver may need to be cleaned try a larger target at closer range.... they don't like dark colors... blk bear is really hard to target and u usually have to select a target close to bear... same as dark colored deer.... the laser gets absorbed instead of reflected
Dec 02, 2014 | Optics
Why i keep getting th error oxc0000005 when i try to on chrome google
Try below steps to fix error code 0xc0000005:
1. Locate Google Chrome shortcut on the desktop or in the start menu.
2. Right Click on the shortcut and open Properties.
3. Now go to the Shortcut tab and you'll see a field named Target.
4. Add the following attribute at the end of the Target Field after giving a space: -no-sandbox
5. You are done. Now restart Chrome and you won't see that error message again.
GuruAid.com
Oct 16, 2014 | Microsoft Windows XP Professional
What are lawn darts?
According to Wikipedia "Lawn darts is a lawn game for two players or teams. A lawn dart set usually includes four large darts and two targets. The game play and objective are similar to both horseshoes and darts. The darts are similar to the ancient Roman plumbata. They are typically 12 inches (30 cm) long with a weighted metal or plastic tip on one end and three plastic fins on a rod at the other end. The darts are intended to be tossed underhand toward a horizontal ground target, where the weighted end hits first and sticks into the ground. The target is typically a plastic ring, and landing anywhere within the ring scores a point."
Sep 22, 2013 | Sport & Outdoor - Others
What do you score till in a game of crazy eights shuffleboard?
A game of crazy eights final score is determined by the players. Before each game, players determine what numerical target they want to reach.
Aug 20, 2012 | Sport & Outdoor - Others
97 chevy 5.7 crank sensor location
The CKP (Crankshaft Position) sensor is located in the front engine cover and is perpendicular to the crankshaft target wheel. The air gap between the sensor and the wheel is preset and not adjustable. The target wheel has three slots 60 degress apart and is keyed to the crankshaft. As the target wheel rotates, the slots passing by the sensor create a change in the magnetic field of the sensor which results in an induced voltage pulse. One revolution of the crankshaft results in three pulses (3x signal). Based on these pulses, the VCM is able to determine crankshaft position and engine speed. The VCM then activates the fuel injector and provides a spark to the Distributor. The relation between the crankshaft position sensor and the target wheel is crucial. The sensor must be exactly perpendicular to the target wheel with the correct air gap.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 15, 2012 | Cars & Trucks
I cannot oppen my yahoo icon
If you are referring to the YM shortcut on your desktop, please check if the icon still points to YahooMessenger.exe. Right click on the icon and click properties. If you had installed it on the default path it should have "C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" on the Target field at the Shortcut tab.
In case you had installed it on a different path, you may search for "YahooMessenger.exe" on your PC, and change the Target field accordingly, depending on the path of search result.
Hope this helps.
P.S. I'm using Windows XP.
Feb 17, 2011 | Yahoo Messenger
Tasco 6-24x42mm rifle scope parallax adjustment
Here's what you need to know about Mil Dots and rangefinding.
When you look through the scope you should see 5 mil dots on each axis, your scope may have broad lines taking place of the 5th mil dot if it is a "modified" mil dot scope. For measuring purposes, 1 mil is the distance from the center of one dot to the center of the one directly above or below it. 3/4 of a mil is the distance from the top of one dot to the bottom of the one above it, or the "space in between dots". 1/4 mil comprises a single dot, the space between the top of one dot and the bottom of that same dot.
A quick calculation is Size of Target (In Yards) x 1000 / Size of target in mils = Range in Yards
Miliradian or "Mil" is an angular unit of measure, so if you were shooting at 1000 yards and moved up 1 miliradian that would be one inch impact moved up.
Anyway lets say you have a 30" target and we need to find the range... using your scope you place the bottom of the target at the CENTER of a mil dot and count how many mils up, good estimation is key... I'll draw a little text diagram, an asterisk * will be the target top and bottom, and parentheses () will be a mill dot
Now lets assume the asterisk on the left is the bottom of your target and the one on the right is the top, I put Ten Hyphens in between each dot so if you count from the left you should get about 1.6 Mils. Its real easy to do it in your head, you already know two whole dots is one mil so you just have to estimate whats to the right (or top if you were looking down a scope).
So we know the target is 30" and we have a Mil Reading of 1.6
30/36= .833 so 30" is .833 Yards
So now we can use the equation .833 x 1000 / 1.6 = 520.6 Yards is the distance of the target
Now you can also use Mil dots to do hold over for when the target moves or for wind and elevation but that gets extremely complicated.
Parallax in Rifle Scopes is explained here
http://www.6mmbr.com/parallax.html
There are many books and websites to confirm what I've said here, but the best way is to go out to your range and talk to some long range shooters and show them your rifle/scope etc and get hands on help.
Mar 16, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
22 people viewed this question
Top Target Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Target Office Equipment and Supply Expert? Answer questions, earn points and help others
