Question about Neptune Washing Machines
Matag Neptune Front load washer door won't open
MAH6700AWW
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
  • 398 Answers
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Posted on Feb 19, 2009
aborcass
  • 2651 Answers
SOURCE: I need a diagram for a maytag neptune mah5500bbw washer
here you go!
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Posted on Mar 20, 2009
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
  • 56 Answers
SOURCE: Have a Maytag Neptune front
look under the soap dispensor at the front edge you should see a green plastic wire that unlocks the door
Posted on Jun 30, 2009
How do I check the drain pump on Maytag neptune washer
I have a matag front load washer MAH6500AWW the door won't lock it just clicks
Apr 07, 2012 | Maytag Neptune MAH5500B Front Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Front loading maytag washer door won't open. Help!!
Remove the lower front panel.Reach up inside near the latch. Feel for a ring tab. Pull it down firmly while pulling on the door.
Then open the cabinet and check all the wire connections in the latch circuit. Check the wax motor ohms. The wax motor probably needs replacing.
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
How do I open the top of my front load washer (Neptune Mod. MAH3
there 3 screws on the back u take off but to take door latch off u dont need top off u open your door take the spring off the front of your boot then remove the screws from door latch reach back there behind boot unplug put new in and put back togather
Apr 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
23 people viewed this question
Top Neptune Washing Machines Experts
gbob59
Eric Taylor
Are you a Neptune Washing Machine Expert? Answer questions, earn points and help others
