Question about John Deere Garden
What year is my john deere lawn tractor - John Deere Garden
  • John Deere Master
  • 7,515 Answers
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Posted on Apr 25, 2017
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 138 Answers
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Posted on Sep 06, 2009
  • 15371 Answers
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Were do you check the transmission fluid on a john deere lx173 lawn tractor?
i am not familiar with John Deere but most lawn tractors dont have a way to check the fluid they are sealed.
Sep 04, 2017 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
My John Deere 4010j traveling sprinkler which is about one year old all of a sudden stopped travelling. What might be the problem? John H. Pensacola, FL
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 09, 2011 | John Deere Gilmour Traveling Sprinkler -...
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
John deere 116 lawn tractor
Call any John Deere dealer directly and they will tell you.
Apr 06, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
