Question about KitchenAid Refrigerators
Kitchenaid frigerator light bulb shield will not move back. Need to change bulb.
    New Friend:
  • 28 Answers
According to Kitchenaid, those lights are LEDs and should never need changing.
call for assistance
or service. In the U.S.A., call
1-800-422-1230. In Canada call
Posted on Apr 24, 2017
2 Suggested Answers
  • 17130 Answers
SOURCE: I need detailed instructions on how to change
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
Posted on Oct 28, 2011
Light shield will not slide back. Need to change frig bulb. Shield will not move. Tight bid it stuck?
not supposed to be changed... they are LEDs so sealed in.. Kitchenaid suggest you call their people.
call for assistance
Apr 24, 2017 | KitchenAid Refrigerators
How do I change the light bulb in a KCM155j Mircowave
Most microwaves have a shield over the light bulb in the cooking compartment. Some are accessed from the outside most from the inside. Check to see if there are clips or screws that need to be removed to pull the shield off. Careful if there are screws, they are usually coated to prevent the waves from arcing if you crack or break off the coating you could have problems with the microwave arcing
Jan 11, 2014 | KitchenAid KCMC155J Convection/Microwave...
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
How to change the light bulb
Not all bulbs will fit your refrigerator. Be sure to replace the bulb with one of the same size, shape and wattage. On some models, the dispenser light requires a heavy duty 10-watt bulb. All other lights require a 40-watt bulb.
1. Unplug or disconnect power from your refrigerator.
2. Remove light shield when applicable.
NOTE: To clean the ligt shield, wash it with warm water and liquid detergent. Be sure to dry the shield thoroughly before installing.
3. Remove the light bulb and replace it with the same size, shape and wattage.
4. Replace light shield when applicable.
Also check this link bellow:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
May 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01?
Hi, just follow the instruction below...
1. Essentially, open the oven door and remove the plastic vent strip between oven and microwave (4 screws). There will be 2 screws under that which secure the microwave unit to the frame. Remove those...
2. Open the microwave door and remove the plastic vent shield at the top (3 screws). At that point, the microwave unit will slide out from the frame as describe above. The light is to the rear of the large silver pad (I removed mine to facilitate reaching the light). If you look at the parts diagrams online, it will be obvious what to look for. I have the light out and sure enough, OSRAM 64405S....
Took me maybe 5 minutes to remove...
Take care
Apr 23, 2010 | Kitchen Ranges
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Nov 24, 2008 | Sub-Zero 690 Side by Side Refrigerator
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Refrigerators Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
