Question about Refrigerators
Ordered water filters for fridge #46-9990 quantity 2 received from discount filters 2011 Southtech drive suite 100 Greenwood Indiana 46143 ordered 2 they don't fit need to return them
    Master:
  • 923 Answers
They don't fit ... in the original shipping box you received them in? Then try using a bigger box! What's your question? Does your refrigerator have a brand name? If so, what is it?
Posted on Apr 24, 2017
Looking where to purchase drive belt for technics SL-MC400 Its rubber approx. 1-1/8" Dia.x 5/64"
try taking the old belt to ace hardware and looking for a comparable sized o-ring. that should work just as well.
Oct 07, 2014 | Audio Players & Recorders
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
Ge profile PSS26MGP side by side installed in Oct 2008. Background: on 1-03-2011 freeze-refer temps approx 13 and 48, apples in top deli-fresh drawer were frozen. Ice maker not making ice, minimal water...
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a Side x Side style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing,or an inefficient not 100% pumping compressor.
Feb 07, 2011 | Refrigerators
Wen driving like wen i *** to a stoplight or complete stop sumtimes it will shake and cut off but if i give it a lil gas it will nt cut off
The symptom is not having correct Fuel air mixture.
Make sure to do in order
1- Change the new air filter.
2- Have Fuel filter replaced.
3- Have Fuel pump delivered correct quantity per sec.
4- Have Fuel distributor calibrated
Good luck.
Aug 09, 2010 | Mercedes-Benz C-Class Cars & Trucks
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I NEED TO FIND A REPAIR FACILITY IN GREENWOOD INDIANA, 46143 FOR MY DVD RECORDER. THANK YOU
http://www.fixya.com/repair/stereos_video_equipment/us/in/greenwood
I am sure that you will find a suitable place in the list above
Sep 08, 2009 | Cyberhome CH-DVR1500 DVD Recorder
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
