Question about KitchenAid Refrigerators
Light shield will not slide back. Need to change frig bulb. Shield will not move. Tight bid it stuck?
    New Friend:
  • 28 Answers
Not supposed to be changed... they are LEDs so sealed in.. Kitchenaid suggest you call their people.
call for assistance
or service. In the U.S.A., call
1-800-422-1230. In Canada call
1-800-807-6777.
Posted on Apr 24, 2017
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
Kitchenaid frigerator light bulb shield will not move back. Need to change bulb.
According to Kitchenaid, those lights are LEDs and should never need changing.
call for assistance
1-800-807-6777.
Apr 24, 2017 | KitchenAid Refrigerators
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
How to change the light bulb
Hi
Not all bulbs will fit your refrigerator. Be sure to replace the bulb with one of the same size, shape and wattage. On some models, the dispenser light requires a heavy duty 10-watt bulb. All other lights require a 40-watt bulb.
1. Unplug or disconnect power from your refrigerator.
2. Remove light shield when applicable.
NOTE: To clean the ligt shield, wash it with warm water and liquid detergent. Be sure to dry the shield thoroughly before installing.
3. Remove the light bulb and replace it with the same size, shape and wattage.
4. Replace light shield when applicable.
Also check this link bellow:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/1403
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Change tag light bulb
  1. Remove two screws retaining the lamp to the rear license plate lamp shield.
  1. Rotate socket one quarter turn from backside of lamp and remove the miniature bulb (13466) .
  1. Install new miniature bulb into socket.
  1. Install socket in lamp .
  1. Secure lamp to rear license plate lamp shield with two screws and tighten to 2 Nm (18 lb-in).
    Item Part Number Description 1 13508 Rear License Plate Lamp Shield 2 14A583 Lamp Lead Wire 3 383356-S Nut (4 Req'd) 4 56000-S Screw (4 Req'd) 5 13550 Lamp (2 Req'd) 6 13466 Miniature Bulb (2 Req'd) A — Tighten to 2 Nm (18 Lb-In)
Feb 27, 2010 | 1998 Ford Windstar
Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Nov 24, 2008 | Sub-Zero 690 Side by Side Refrigerator
Infiniti M35 - change headlight Bulb
Take the wheel off the side with the burnt out bulb. Next pull the 6 plastic rivets out of the front fender well shield. Take the screw out of the shield above the 3 rivets along the inside of the fender edge, Pull the shield back starting at the top where it's tucked under the back portion of the liner shield. Unscrew the top plastic cover, twist the connector counter clockwise and pull it off the bulb. Then unclip the bulb and pull the bulb out noting the groove position for reinstalling the new bulb in the housing. There is nothing simple about your bulb change. The dealer price of the bulb is around $245.00. Don't break the new bulb trying to guess when it's seated properly!
May 18, 2008 | 2006 Infiniti M35
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
