Question about Tomtom ONE GPS Receiver
Unit will not charge
Unit was charging until recently,but noticed no green light further investigation revealed unit would now only charge by holding in car charger connector on base of GPS in a very specific position. This worked for a short time but has now stopped working altogether..
    Problem Solver:
  • 7 Answers
Call tech support at 866-486-6866. If you bought this unit within the last year, something will be done. In the mean time you can charge the unit via the USB cable, it will pull power from there.
Posted on Nov 27, 2007
Will not run on battery. charged battery but will not hold charge.
Hi Martha, had a bit of a look around and noticed a few mentions of charging problems including the following - 'One of these units was apparently dead on arrival and on further investigation, it worked off mains but not from battery. The battery comes out from a flap underneath the unit, and on testing with a multimeter, it was under voltage, so must have been old stock. Despite 2 days of charging, no life, so I ordered a replacement battery (RITAR RT1250 or equivalent 12v battery) and it works fine. I also have a proper battery charger rather than use this unit's own charger, which charges the battery rapidly, but I think at the cost of battery lifespan. Given that I use this unit infrequently, this is fine, otherwise use the internal charger as normal. With the new battery, I've never managed to run out of battery.. it will keep going all day on a single charge.
The manual does state that if you don't charge the unit at least every 6 months, it may not charge.'
I know it's not exactly a resolution but hope it helps!
Jun 16, 2015 | ION Audio Tailgater Portable Pa System For...
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
When you charge your battery in the nail gun should the indicator light turn green on the charger
generally when charging the light will be red until a full charge is indicated and the light will turn green. if while trying to charge the light remains green I would try reinserting the battery or charging unit. If still the same you might have a problem with either.
Apr 15, 2011 | Hitachi Tools & Hardware - Others
Battery does not hold charge Put battery on changer until light is green Battery losses charge within 2 mintues on flash light unit and quicker in drill unit. Where do I find replacements?
Some battery places will repack NiCD and other types oif battery packs for you. Otherwise ask at the place you bought it or a similar specialist shop as they may be able to order one in for you.
Feb 11, 2011 | Garden
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
How to tell if unit is charging?
When you power up and its charging the green light will flash, when it is fully charged, the green light will stop flashing
let me know if i can be of further assistance
Kim Ganoe
Mar 11, 2010 | Symbol PDT 3100
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
65 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
