Question about Cycling
How do i grease the crank set - Cycling
  • 4,411 Answers
If there is no roughness in the bearings and no adjustment is required there is no need to dismantle. There is usually sufficient clearance between the crankshaft and the bearing cups to allow a low viscosity lubricant into the bearing when the machine is laid on it's side. Older high quality touring machines were actually fitted with a bottom bracket lubrication point...
Low viscosity oil is exactly what a bike/maintenance oriented/sporting type would want but for everyman everyday use grease is what is needed but grease won't go through the gap. I use an aerosol of cable, chain and bearing lube. When first sprayed from the can it is a thin black penetrating fluid but after it has been exposed to the atmosphere the solvent evaporates leaving a semi-liquid moly grease that is anti-fling and an excellent bearing lubricant.
Posted on Apr 24, 2017
  • 19,071 Answers
How do I put on the bike sprocket on my huffy bike
If its a onepiece crankset, there should be a large bolt on the rear side. This bolt is bvackwards threads. Tighten spocket cone, grease the bearing on that side of the bike. Put crankarm thru frame, put other bearing in, with ample supply of grease. Tighten cone, add washer, then locknut. Crank bearinbgs should be set so they spin freely without extra up and down motion or slop.
Oct 02, 2014 | Cycling
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
Machine is Quivering while excersisng
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Lubrication
Drive Belt
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
Quivering while excersising
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Loose crank
It is adjustable. But I would suggest to take it apart and lube the bearing assm.'s then set the adjustment. When setting the adjustment gently tighten the nut spin the sprocket assm. 5 or so turns to allow grease to spread evenly then back off the nut slightly and tighten nut enough to set a zero spec. in other words no side to side play and yet not tight (to tight and you can harm the bearings)
Mar 07, 2013 | Diamondback Outlook, 2012 171841
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
