My quickset lock won't stop beeping - Computers & Internet
Tightening a Quickset exterior door handle--can't get to the screws under the faceplate.
This should help you with your Quickset Lock problem.
It is not my Video, I am just passing it as found on you tube.
Good Luck.
Jul 04, 2017 | Home
Can not set the date and day
I assume you are talking about a day-date Timex. Timex watches do have a quickset feature meaning the day and date can be set without having to simply advance the time by 24 hours to adjust the Day-Date. Not all watches have a quickset, but I'm sure your Timex does. Unscrew the crown from the stem by turning it counter clockwise until it is free from the threads. At this point pull the crown all the way out so that you can adjust the time. That's position 2 the quickset is in position 1 but the tricky part is getting the crown in the proper position to engage the quickset. Push the crown in very slowly while turning once you see the day or date window advance stop turning you are in position 1. Day and date can be set in this position by turning the crown in either direction. If your watch does not have a quickset or you cannot figure out how to engage it you must set the date by advancing the time forward 24 hours. This will make the date window advance by one day. Once the right date is displayed turn the time backwards 24 hours and this will cause the day window to move without affecting the date window. And that's all there is to it.
Dec 31, 2013 | Watches
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
How to stop the beeping when I lock my car?
There is probable nothing wrong as several cars beep when the cars are locked. It is to let you know that the car is locked If you have a door not properly closed it won't lock and therefore will not beep.. Just a reminder that the system is secure.. My car dosen't beep but instead if lashes the park light twice on lock and once on unlock
Feb 01, 2013 | 2012 Volkswagen New Beetle
Quickset door locking knob cannot be locked from inside without jijjling the knob
a shot of WD-40 in the key hole. also spray the key with WD-40 just before inserting
Nov 22, 2012 | Kwikset Locks & Locksmithing
Why won't my 2011 elantra beep when I lock it with the remote
Some cars you have to set up to beep when locking. Are you pushing the lock button twice.
Apr 27, 2012 | 2011 Hyundai Elantra
I just had my brakes changed on my 2006 passat. Now the electronic parking break sensor won't stop beeping but everything works. How can I get the fault to go away so It will stop beeping
also if u take battery off for 10 mins, hook battery back up again, turn car on, hold in break paddle for 35 seconds, then still holding in break paddle hold in handbrake button for 10 seconds, release all and start car up, press break button a few times, turn car off again take out key, lock and open car then press break button again and now all should b back to normal
Mar 27, 2012 | 2006 Volkswagen Passat
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
Computers & Internet Logo
David Payne
David Payne
