Question about Microsoft Xbox 360 Console
My xbox 360 wont turn on can some one help
The orange light is on but my 360 wont turn on
  • 42 Answers
The A/V cables are not pushed in all the way
Posted on Jul 24, 2009
SOURCE: power cable light is orange and xbox 360 wont turn on
Hmm sounds similar to me. I saw a post stating that usb port where the controllers are connected were shorting out to ground. So I took my 360 apart and sure enough the pins were shorted to ground. A good thing to check is the orange light on the power brick. If before you plug it into the back of the 360 its a steady orange light and then you plug it into the console it blinks (pay attention) its a good possibitility that it is shorting out somewhere in the console. If you have a mulitmeter you can check the back of the power plug input to ground or the controller usb to ground. Even though I found that this was my problem with my xbox unfortunately for me my board was also fried. From now on Im going to collect xbox's that are broken and use them to fix my new xbox when it breaks(im sure it will) because microsoft enjoys putting out an infererior piece of ****. I'll be dam*** if ill pay anyone a penny and wait half a year to get a repaired (but still broken) xbox back, when I know Ill be able to fix my own. Maybe Ill open up my own 360 repair shop just to show microsoft how. customer service should be handled. Anyway hope that helps and you have better luck then I did.
Posted on Mar 28, 2009
nealj121
  • 152 Answers
SOURCE: power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Posted on Apr 10, 2009
  • 10 Answers
SOURCE: my xbox 360 won't turn on!!!
That means that the Power box is waiting for the console to be connected. if it does not work again then you can call xbox support to check the warranty of your xbox 360 then send it for repair.
I hope that will help you.
Posted on Apr 19, 2009
v4ndre
  • 148 Answers
SOURCE: My xbox 360 power supply has an orange light and
could be a simple broken power button or maybe a cracked solder point in the base of your console female power plug...
or even a internal eletrical problem...
Check and test with another power supply...
Good Luck...
Posted on Sep 11, 2009
SOURCE: MY Power Supply light is blinking orange and xbox
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Posted on Nov 10, 2009
My xbox 360 e power brick have orange light when not plug in the xbox, but when plug in it have no light but fan is running and xbox wont turn on, and this is a new xbox.
I have the same issue sometimes with my 360. You are going to have to unplug it from the wall, let it completely power down, then plug it into the 360 first, then the wall. It should work then.
Feb 20, 2014 | Microsoft Xbox 360 Console
Power supply light stays orange and wont turn on the XBOX PRO. HELP!
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Jan 04, 2011 | Microsoft Xbox 360 Pro System Console
My sons xbox 360 wont turn on
Check the power supply unit, if the light is green or orange and still doesn't power on, try pressing the eject button on the xbox it should turn on if you do, if the power supply is red then you should contact xbox support.
Oct 21, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
My 2 month Xbox 360 wont even turn on. the orange light on the black power box is on but the system wont even turn on
if less than 12 months take back to retailer for a replacement or send to microsoft for repairs. Good luck.
Nov 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont turn on al all(not rrod)
Have you fully unplugged it and as in the mains from the adaptor, adaptor from the 360 etc? then re-plugged it?
If this does not help then i think you may need to visit http://www.xbox.com/en-GB/support
Oct 29, 2009 | Microsoft Xbox 360 Console
My xbox 360 will not turn on but the power block light is orange
There can be a number of reasons for an Orange light on the Power Adapter. Here is the official link to MS help:
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=906102&lcid=1033&category=hardware
Hope this helps.
Jul 21, 2009 | Microsoft Xbox 360 Console
Xbox360 Power source
there could be a possiable problem with the brick part of the power source
Feb 13, 2009 | Microsoft Xbox 360 Console
Xbox360
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one
Sep 06, 2008 | Microsoft Xbox 360 Console
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
119 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
