Enlarge print?do I need book open? - Office Equipment & Supplies
I am reading a book on my new Aura Kobo ereader, the print is too small, how do I get back to menu to change size of print?
No menu required. Just use two fingers on the screen and slide them apart. Be careful, it's easy to get very big, very quickly.
To get smaller slide two fingers together on the screen.
Feb 20, 2015 | Kobo Aura E-Reader
I placed a book on the copier and tried to copy it in a larger print but could not find a setting to make the printed page larger
The model of copier you're using is going to determine the verbiage the manufacturer uses but I have seen both "enlarge" and "zoom".
Mar 19, 2011 | Computers & Internet
CAN NOT SET CURRENT TIME AND NEED LARGER PRINT INSTRUCTIONS
You posted under Intermatic ST01C timer.
Open following link to identify timer and see on-line printing that can be enlarged using CTRL key and scroll wheel on mouse.
You can also download the manual in pdf format and use magnifying glass icon on adobe reader to enlarge print
http://waterheatertimer.org/ST01C-program.html
If ST01C is not your timer, resourceful do-it-yourselfer can find links to additional timers on link above, or add a comment with EXACT model number and I will find on-line manual that you can enlarge.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do I enlarge a page so I can read it? When printing something from the internet, how do I enlarge the print? I have printed a pattern and cannot read it.
There's no option to enlarge the font or text of what you are printing from the Internet. What you need to do is to copy the page that you would like to print and then paste it in a Word document.
From the Word document, there's an option for you to change the font size and color.
Have a great day!
Dec 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Need to replace door handle
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 28, 2009 | Frigidaire FMV156DC Microwave Oven
Can't figure out how to enlarge a Photo
open the picture using windows explorer, choose print from there and you will be given options on the size of the picture that you want to print.
I hope this helps
Dec 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Need to enlarge the print on my HP DeskjetD4160 - it's soo tiny
Are you using Internet Explorer, as you brower? If so go tothe top of an open browser window left click on "page", go down to text size and select the size you want. If you don's see "page" click on menu bar, it should open up the options available, there. It's right next to tools. that should do it. Also if you want larger text when viewing websites, click on View, and you can adjust the text the way you want it to look.
Dec 03, 2008 | Computers & Internet
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
How to enlarge print on copier
To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'.
Access the printing preferences by opening the printer Properties/ Preferences.Click here and follow instructions in this document.
Mar 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
k24674
jasbo
jasbo
