Question about Electronics - Others
My magic chef hmbr350seI refer does not work on 450 watt pure sine inverter, It did, now it stopped., it still works on inside house AC-DC power, what happened?
    New Friend:
    Problem Solver:
  • 8 Answers
Check the fuse on the inverter & see if any other devices work on it !! God bless !!!
Posted on Apr 24, 2017
DIAGRAM FOR A 1983 NEWMARK POWER CONVERTER 110 TO 12 VOLT. ITS IN A 1983 CONESTOGA TRAVEL TRAILOR AND IM TRYING TO FIGURE OUT WHY HALF OF MY OUTLETS ARE WORKING AND THE OTHER HALF HAVE VERY LOW VOLTA
Hello Neal Behm,
You would be lot more likely to attract FREE HELP...
if you attempted to look for your MODEL NUMBER...!!
In so doing you will find that your "INVERTER" is not
a "NEWMARK" but is correctly called a "NEWMAR"
(pure sine) inverter...
Also CRITICALLY important...
(since every "motor-home" is typically unique)...
Is your AC power configured for "Grid" POWER...??
In general your model number will look like the
one listed below...
NewMar 12 1800IC Installation Operation Manual Inverter Operation Start up...
Hope this gets you started
Newmar, Onan... Allan-Bradley are all good
reliable equipment ... PRETTY EXPENSIVE...
You might want to consider the valve of this
>> KNOWN BAD << one... (( no good... Parts only ))
before experimenting on YOUR inverter!!
Not cheap...!!
NEWMAR 12 1200IC EV PURE SINE WAVE DC TO AC POWER INVERTER CHARGER 1200W...
I'm just saying...
Carnac the Magnificent
Apr 24, 2018 | Cars & Trucks
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
My 12 V 400 watt inverter worked fine until recently, when in would no longer power anything. I checked the AC output voltage and am gettting only 25 volts, rather than the 110-120 volt range. Any...
My guess would be the power oscillator mosfets. Was the 25V AC or DC? If there is no AC and the output is DC then the chances are very good that one of the switching mosfets that produce the AC is shot. These are usually set up in an H-Bridge configuration and both the neutral and hot leads alternately get switched between high voltage DC and ground, producing a modified sine wave output. For the cost of one of these inverters, it might be cheaper to just buy a new one and recycle the old.
Jan 19, 2018 | Vector 400 Watt Power Inverter #VEC024
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
Jan 15, 2018 | Xantrex Technology Ags Harness Cable...
Went u turn it on the red lite comes on and wont turn green and wont work its a road pro rppi-1500w
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Jan 07, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
Power jack 3500w inverter power problems.
It's complete garbage design. See here:
http://ludens.cl/Electron/chinverter/chinverter.html
Aug 10, 2009 | Statpower PW-1750 Triple Outlet 1750 Watt...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Electronics - Others Logo
149 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
