Question about Toshiba Televison & Video
Got an older (2008)27(?) as a gift. Cannot get TV to work on one handpiece-takes the Toshiba handpiece to Turn on, mute, and off. Cable handpiece controls channel selection.
Tried Toshiba instructions to select channels-used automatic search several times--did not work. Would like to use one handpiece!
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
Coldcut
  • 1554 Answers
SOURCE: Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Posted on Apr 25, 2008
  • 362 Answers
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Posted on Jan 09, 2009
  • 6 Answers
SOURCE: Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
Posted on Sep 07, 2010
Remote handpiece for Pioneer Plasma TV?
Have you tried new batteries? Make sure there are no objects blocking sensor on TV. Paper, packaging, clear protective films from original shipping, ...
May 07, 2014 | Pioneer Televison & Video
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
to test it ,play a DVD ,you must have pictures and audio together..
Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
ON-LINE INSTRUCTIONS???
One of the most recognizable makers of TVs in the world is Toshiba. The company's TVs are found in every major electronics store at a reasonable price. Packed with features, they have a model for everyone, whether it be LCD or older, tube-based CRT technology. Toshiba T.v are fairly easy to operate. Basic functions
  • Before you do anything with your Toshiba TV, you have to plug it in to a wall outlet. After plugging it in, locate the power button on the front (or on the remote) and turn on your TV. Depending on if you have cable TV or not, you can use the channel functions to flip between your favorite channels. The "Menu" button is useful to access advanced settings, like channel detection, parental controls, closed captions and picture controls.
  • Using video inputs
  • You can connect a variety of devices to your Toshiba TV via its front, side or rear inputs. If you look at the back, you'll see a variety of audio and video inputs to connect virtually any kind of device. You should see a few kinds of video inputs: Composite and s-video (for connecting older technology like VCRs and cable boxes), component video (for connecting older DVD players) and HDMI (for connecting digital technology like receivers and Blu-Ray players). Audio inputs are analog (red and white) or digital (coaxial and optical). Use digital connections when possible to ensure the best quality.
    To connect VCRs and DVD players, simply connect the proper cable to their audio and video outputs, then match the cable to the proper inputs on the back of the TV. Make sure everything is secure and take note of which input you connected it to. Now, tune your TV to the proper input by pressing "Video" on the remote.
  • Maintenence and tips
  • Your Toshiba TV is a sensitive electronic device, so precautions should be taken to keep it in top working order. If the screen gets dusty, wipe it with a dry, soft cloth. If you own a Toshiba plasma TV, be aware of burn-in and ghosting problems. Avoid watching programs that have static images is left on the TV for hours at a time. If you have a flat-panel Toshiba TV, consider getting it professionally calibrated to get the best possible picture
  • Dec 02, 2009 | Cell Phones
    I have no sound
    go to menu settings and check audio on?
    Jul 10, 2009 | Televison & Video
    Remote won't turn tv off or on. Mute, volume also does not work
    Take the set apart and see if there is a separate board in front of the set. Remove the board and check for cold solder joints first. If o.k., replace sensor. Then again you could contact toshiba and order another key pad for the set.
    Jul 07, 2009 | Toshiba 13A24 13" TV
    Need code to program toshiba tv with Direct tv remote
    someone esle found this.. and it worked for me
    Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
    This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
    Oct 01, 2007 | One For All URC-3021 Remote Control
    Televison & Video Logo
    27 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
